What is the best way to get the log? I assume it is time bound before it gets purged or something? Maybe I’ll upgrade to Trixie and get the new QBittorrent client installed and see what happens
By default it should log into /var/log/qbittorrent/qbittorrent.log.
If not, log into the web UI and in the preferences you can specify a path.
Or, if you only use it via CLI, you can directly edit the config file /home/qbittorrent/.config/qBittorrent/qBittorrent.conf
6 days on still up and running, so guessing something was fixed in V5, although probably just jinxed it by saying that now.
Although, I am seeing a lot of these entries:
Sep 29 10:41:40 DietPi qbittorrent-nox[612]: The legacy data directory │
│ ‘/home/qbittorrent/.local/share/data/qBittorrent’ is used. It is recommended to move its content to │
│ ‘/home/qbittorrent/.local/share/qBittorrent’
