ProFTP: lightweight ftp server
[Info] Please wait…
processing | D i e t P i
[Info] Apt-get is processing, please wait…
Preconfiguring packages …
Selecting previously unselected package libmemcached11:armhf.
dpkg: unrecoverable fatal error, aborting:
files list file for package ‘dropbear’ is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
[Failed] The apt cache may be corrupt, apt mirror offline, or you have held broken pacakages. DietPi-Software will now exit.
[Info] Apt Log:
[Info] Please try:
[Info] - Fixing apt package errors with ‘apt-get install -f’
[Info] - Change apt mirror: ‘dietpi-config’ > ‘Networking: NAS/MISC’ > ‘Apt Mirror’
[Info] - Clear and refresh apt ‘apt-get update’
[Info] - If problems persist, please create a Git ticket so DietPi can investigate the issue:
Which:
- Device installed on
- PSU
- SD card
Please try clearing apt cache:
apt-get clean
rm -R /var/lib/apt/lists/* -vf
apt-get update
Then reselect ProFTP from dietpi-software for install.
Again…
i have a Raspberry PI 3 with 2GB SD card… installing DietPi CAM
DietPi-Services
âââââââââââââââââââââââââââââââââââââââââââââââââââââ
Mode: stop
Please wait…
[Ok] cron
[Ok] proftpd
[Ok] apache2
[Ok] mysql
DietPi-Software
Mode: Install software
Please wait…
DietPi Cam: web interface & controls for your rpi camera
[Info] Please wait…
[Info] Testing connection to https://github.com/Fourdee/RPi_Cam_Web_Interface/archive/6.2.29.zip
[Info] Max duration of 20 seconds, please wait…
[Ok] Connection test | Completed
Extracting templates from packages: 100%
Selecting previously unselected package libasyncns0:armhf.
files list file for package ‘file’ is missing final newline
[Info] Apt Log:
[Info] Please try:
