Problems with the Immich installation script
Hello, DietPi team,
I’m having a problem installing Immich width install script:
- Command: pnpm c set --location=project stateDir /mnt/dietpi_userdata/immich_src/.pnpmState                        │
                                │  - Exit code: 1        │
                                │  - DietPi version: v10.6.2 (MichaIng/master) | HW_MODEL: 4 | HW_ARCH: 3 | DISTRO: 8                                  │
                                │  - Error log:        │
                                │ [ERR_PNPM_CONFIG_SET_NOT_A_PROJECT_SETTING] The key "stateDir" cannot be set in a project's pnpm-workspace.yaml      │
                                │ Set it for the machine instead: pnpm config set --global state-dir
I don’t know what to do. Do you have any ideas?
Looks like they changed behaviour with the release of pnpm 11.22 from August 15th, it can no longer be set with --location=project,
https://github.com/pnpm/pnpm/releases/tag/v11.22.0
But I’m not sure how to fix this, the you would nees to set stateDir now globally, like
pnpm c set --global state-dir "/some/dir"
Looks like this changed from valid to warning to error within a month or so. When we implemented Immich, the command was perfectly accepted. Some weeks ago I saw it started throwing warnings, but without causing an error, now it errors out.
Fixed with: dietpi-software: Immich: fix install · MichaIng/DietPi@1d17404 · GitHub
As a quick fix your end:
sudo sed -i '/pnpm c set --location=project stateDir/d' /boot/dietpi/dietpi-software
Or if you are still at the error handler, just “Change command” to true or :.
Thank you, work fine !!
