Creating an issue
- DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=18
G_DIETPI_VERSION_RC=2
G_LIVE_PATCH_STATUS[0]=‘not applicable’ - Distro version |
bookworm 0 - Kernel version |
uname -a
Linux MotionEyeTwo 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux - Architecture |
dpkg --print-architecture
arm64 - SBC model |
RPi 4 Model B (aarch64) - Power supply used | (EG: 5V 1A RAVpower)
Does not change anything, i’ve tried various - SD card used | (EG: SanDisk ultra)
SAN Disk Max Endurance (the white ones) 32 GB
- Software title | MotionEye
Yes, freshly installed - Can this issue be replicated on a fresh installation of DietPi?
Yes
1.) Login to Motioneye
2.) Try to configure a V4L2 Camera
The camera should light up
The does not show anything in the webinterface
sudo journalctl -u motioneye
Jun 30 15:24:34 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [ERR] [VID] v4l2_device_capability: Device does not support capturing.
Jun 30 15:24:34 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [ERR] [VID] vid_start: V4L2 device failed to open
Jun 30 15:24:34 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [WRN] [ALL] motion_init: Could not fetch initial image from camera
Jun 30 15:24:34 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [WRN] [ALL] motion_init: Motion continues using width and height from config file(s)
Jun 30 15:24:40 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
Jun 30 15:24:40 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [ERR] [VID] v4l2_device_capability: Device does not support capturing.
Jun 30 15:24:40 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [ERR] [VID] vid_start: V4L2 device failed to open
Jun 30 15:24:50 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
Jun 30 15:24:50 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [ERR] [VID] v4l2_device_capability: Device does not support capturing.
Jun 30 15:24:50 MotionEyeTwo motion[2781]: [1:ml1:Camera1] [ERR] [VID] vid_start: V4L2 device failed to open
→ If i try that on a fresh install of motioneyeos it works like a charm…
