Problems with KODI, X/desktop or moving media and sound after upgrade
    G_DIETPI_VERSION_SUB=9
    G_DIETPI_VERSION_RC=0
    G_LIVE_PATCH_STATUS[2]=‘not applicable’
    G_LIVE_PATCH_STATUS[3]=‘not applicable’
  • Distro version | Bookworm 0
  • Kernel version | Linux DietPi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
  • Architecture | ArmHF
  • SBC model | RPI4 4gb
  • Power supply used | RPi4 original
  • SD card used | USB hdd
  • Software title | Kodi, X, any app with moving media
  • Updated/upgraded via dietpi-update to latest version
  • Bug report ID | 0a7f6b27-5280-4472-ae0c-e9c531da3cf4
Kodi or X starting, be able to watch movies with sound.
After successfully applying the update/upgrade to latest verison 9.9 after a 2 week abscence from home during xmas/NYE I got a error from Pipewire in yellow and red colour at boot. Normally Kodi executes as a non root user but after upgrade is stopped at prompt.
I read about the error message online and got a solutions to reinstall Pipewire.
The error message disappeared and I can start Kodi (or desktop LXDE) BUT… whenever sound or moving pictures is involved everything freezes after a few seconds.
I do not know how to fix this.
Update is the only change I have don on the system which has been workign perfectly for a long time.
  • apt policy pipewire
pipewire:
Installed: 1.2.4-1~bpo12+1+rpt1
Candidate: 1.2.4-1~bpo12+1+rpt1
Version table:
1.2.7-1~bpo12+1 100
100 Index of /debian bookworm-backports/main armhf Packages
*** 1.2.4-1~bpo12+1+rpt1 500
500 Index of /debian bookworm/main armhf Packages
100 /var/lib/dpkg/status
0.3.65-3+deb12u1 500
I restored a backup to be able to recreate the Pipewire error message that I originally got after the upgrade to 9.9. Anyone got some ideas? Seems to be a problem with Pipewire. I cannot execute Kodi not even on root account.
Error message as follows (in red and yellow line onscreen):
[W][28886.041626] pw.conf      | [          conf.c: 1214 try_load_conf()] can't load config client.conf: No such file or directory
[E][28886.043303] pw.conf      | [          conf.c: 1243 pw_conf_load_conf_for_context()] can't load config client.conf: No such file or directory
'this->recurse > 0' failed at ../src/pipewire/thread-loop.c:62 do_unlock()
ERROR: Unable to create GUI. Exiting
I’m not an expert on Kodi or Pipewire. I was just searching the web. Seems other have similar error messages using Pipewire.
Some fixed it by switching to pulseaudio https://forums.linuxmint.com/viewtopic.php?t=429103
Others installed some client libraries [cosmetic] warning if pipewire not active · Issue #11790 · mpv-player/mpv · GitHub
Thanks for your answer. I have found similiar articles so I have tried uninstalling Pipewire before posting here in the first place but some info that you provided were new to me. I tried the following:
apt purge pipewire pipewire-bin
apt install pulseaudio
systemctl enable --user pulseaudio (this particular command does not work at all on my rpi4)
sudo reboot
The yellow/red Pipewire error at boot went away. However Kodi (set to autostart at boot on a nonroot user) does not start up but is giving
"ERROR: Unable to create GUI. Exiting"
So back to square one. And I DO NOT understand why this happened after a reboot. I have changed nothing in my setup.
I also wanna add that my LXDE desktop is working perfectly.
can you share the full log while trying to start kodi manually
Do you mean with “startkodi”??
Always getting the exact same error no mater if I start manually or automatic at boot.
Can I get more info from any complete logfile?
This is the errors from $HOME/.kodi/temp/kodi.log after a manual start from CLI:
Pls copy error messages from SSH terminal and add the log file. If possible avoid doing screen prints
I am sorry. SSH just says “ERROR: Unable to create GUI. Exiting” on any account when started manually or automatic.
Here is the log file:
2025-01-23 18:47:06.030 T:21657    info <general>: -----------------------------------------------------------------------
2025-01-23 18:47:06.030 T:21657    info <general>: Starting Kodi (20.5 (20.5.0) Git:20240501-8c8d7afa26). Platform: Linux ARM 32-bit
2025-01-23 18:47:06.030 T:21657    info <general>: Using Release Kodi x32
2025-01-23 18:47:06.030 T:21657    info <general>: Kodi compiled 2024-05-01 by GCC 12.2.0 for Linux ARM 32-bit version 6.6.20 (394772)
2025-01-23 18:47:06.031 T:21657    info <general>: Running on BCM2835 with Debian GNU/Linux 12 (bookworm), kernel: Linux ARM 64-bit version 6.1.21-v8+
2025-01-23 18:47:06.031 T:21657    info <general>: FFmpeg version/source: 5.1.6-0+deb12u1+rpt1
2025-01-23 18:47:06.031 T:21657    info <general>: 4 CPU cores available
2025-01-23 18:47:06.031 T:21657    info <general>: ARM Features: Neon enabled
2025-01-23 18:47:06.031 T:21657    info <general>: special://xbmc/ is mapped to: /usr/share/kodi
2025-01-23 18:47:06.031 T:21657    info <general>: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2025-01-23 18:47:06.031 T:21657    info <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2025-01-23 18:47:06.031 T:21657    info <general>: special://masterprofile/ is mapped to: /home/dietpi/.kodi/userdata
2025-01-23 18:47:06.031 T:21657    info <general>: special://envhome/ is mapped to: /home/dietpi
2025-01-23 18:47:06.031 T:21657    info <general>: special://home/ is mapped to: /home/dietpi/.kodi
2025-01-23 18:47:06.031 T:21657    info <general>: special://temp/ is mapped to: /home/dietpi/.kodi/temp
2025-01-23 18:47:06.031 T:21657    info <general>: special://logpath/ is mapped to: /home/dietpi/.kodi/temp
2025-01-23 18:47:06.031 T:21657    info <general>: Webserver extra whitelist paths:
2025-01-23 18:47:06.031 T:21657    info <general>: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin
2025-01-23 18:47:06.031 T:21657    info <general>: Local hostname: DietPi
2025-01-23 18:47:06.031 T:21657    info <general>: Log File is located: /home/dietpi/.kodi/temp/kodi.log
2025-01-23 18:47:06.031 T:21657    info <general>: -----------------------------------------------------------------------
2025-01-23 18:47:06.031 T:21657    info <general>: loading settings
2025-01-23 18:47:06.032 T:21657    info <general>: special://profile/ is mapped to: special://masterprofile/
2025-01-23 18:47:06.051 T:21657    info <general>: No settings file to load (special://xbmc/system/advancedsettings.xml)
2025-01-23 18:47:06.051 T:21657    info <general>: Loaded settings file from special://profile/advancedsettings.xml
2025-01-23 18:47:06.052 T:21657    info <general>: Contents of special://profile/advancedsettings.xml are...
                                                   <advancedsettings>
                                                     <cache>
                                                       <buffermode>1</buffermode>
                                                       <memorysize>314572800</memorysize>
                                                       <readfactor>15</readfactor>
                                                     </cache>
                                                   </advancedsettings>
2025-01-23 18:47:06.052 T:21657 warning <CSettingsManager>: missing version attribute
2025-01-23 18:47:06.053 T:21657    info <general>: Default Video Player: VideoPlayer
2025-01-23 18:47:06.053 T:21657    info <general>: Default Audio Player: paplayer
2025-01-23 18:47:06.053 T:21657    info <general>: Disabled debug logging due to GUI setting. Level 0.
2025-01-23 18:47:06.053 T:21657    info <general>: Log level changed to "info"
2025-01-23 18:47:06.053 T:21657    info <general>: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2025-01-23 18:47:06.055 T:21657    info <general>: creating subdirectories
2025-01-23 18:47:06.055 T:21657    info <general>: userdata folder: special://masterprofile/
2025-01-23 18:47:06.055 T:21657    info <general>: recording folder:
2025-01-23 18:47:06.055 T:21657    info <general>: screenshots folder:
2025-01-23 18:47:06.059 T:21657    info <general>: Running database version Addons33
2025-01-23 18:47:06.157 T:21657    info <general>: CAddonMgr::FindAddons: audioencoder.kodi.builtin.aac v1.0.2 installed
2025-01-23 18:47:06.157 T:21657    info <general>: CAddonMgr::FindAddons: audioencoder.kodi.builtin.wma v1.0.2 installed
2025-01-23 18:47:06.157 T:21657    info <general>: CAddonMgr::FindAddons: game.controller.default v1.0.42 installed
2025-01-23 18:47:06.158 T:21657    info <general>: CAddonMgr::FindAddons: game.controller.keyboard v1.1.43 installed
2025-01-23 18:47:06.158 T:21657    info <general>: CAddonMgr::FindAddons: game.controller.mouse v1.0.26 installed
2025-01-23 18:47:06.158 T:21657    info <general>: CAddonMgr::FindAddons: game.controller.remote v1.0.27 installed
2025-01-23 18:47:06.158 T:21657    info <general>: CAddonMgr::FindAddons: game.controller.snes v1.0.40 installed
2025-01-23 18:47:06.158 T:21657    info <general>: CAddonMgr::FindAddons: inputstream.adaptive v20.3.18 installed
2025-01-23 18:47:06.159 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.global.audioengine v1.1.1 installed
2025-01-23 18:47:06.159 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.global.filesystem v1.1.8 installed
2025-01-23 18:47:06.159 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.global.general v1.0.5 installed
2025-01-23 18:47:06.159 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.global.gui v5.15.0 installed
2025-01-23 18:47:06.159 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.global.main v2.0.2 installed
2025-01-23 18:47:06.159 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.global.network v1.0.4 installed
2025-01-23 18:47:06.160 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.global.tools v1.0.4 installed
2025-01-23 18:47:06.160 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.audiodecoder v4.0.0 installed
2025-01-23 18:47:06.160 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.audioencoder v3.0.0 installed
2025-01-23 18:47:06.160 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.game v3.0.0 installed
2025-01-23 18:47:06.160 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.imagedecoder v3.0.1 installed
2025-01-23 18:47:06.160 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.inputstream v3.2.0 installed
2025-01-23 18:47:06.161 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.peripheral v2.0.0 installed
2025-01-23 18:47:06.161 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.pvr v8.2.0 installed
2025-01-23 18:47:06.161 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.screensaver v2.2.0 installed
2025-01-23 18:47:06.161 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.vfs v3.0.1 installed
2025-01-23 18:47:06.161 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.videocodec v2.0.3 installed
2025-01-23 18:47:06.161 T:21657    info <general>: CAddonMgr::FindAddons: kodi.binary.instance.visualization v4.0.0 installed
2025-01-23 18:47:06.162 T:21657    info <general>: CAddonMgr::FindAddons: kodi.resource v1.0.0 installed
2025-01-23 18:47:06.162 T:21657    info <general>: CAddonMgr::FindAddons: metadata.album.universal v3.1.10 installed
2025-01-23 18:47:06.162 T:21657    info <general>: CAddonMgr::FindAddons: metadata.artists.universal v4.3.12 installed
2025-01-23 18:47:06.162 T:21657    info <general>: CAddonMgr::FindAddons: metadata.common.allmusic.com v3.2.2 installed
2025-01-23 18:47:06.162 T:21657    info <general>: CAddonMgr::FindAddons: metadata.common.fanart.tv v3.6.4 installed
2025-01-23 18:47:06.163 T:21657    info <general>: CAddonMgr::FindAddons: metadata.common.imdb.com v3.2.9 installed
2025-01-23 18:47:06.163 T:21657    info <general>: CAddonMgr::FindAddons: metadata.common.musicbrainz.org v2.2.4 installed
2025-01-23 18:47:06.163 T:21657    info <general>: CAddonMgr::FindAddons: metadata.common.theaudiodb.com v2.0.3 installed
2025-01-23 18:47:06.163 T:21657    info <general>: CAddonMgr::FindAddons: metadata.common.themoviedb.org v3.2.19 installed
2025-01-23 18:47:06.163 T:21657    info <general>: CAddonMgr::FindAddons: metadata.generic.albums v1.0.18 installed
2025-01-23 18:47:06.163 T:21657    info <general>: CAddonMgr::FindAddons: metadata.generic.artists v1.0.14 installed
2025-01-23 18:47:06.164 T:21657    info <general>: CAddonMgr::FindAddons: metadata.local v1.0.1 installed
2025-01-23 18:47:06.164 T:21657    info <general>: CAddonMgr::FindAddons: metadata.themoviedb.org v5.3.0 installed
2025-01-23 18:47:06.164 T:21657    info <general>: CAddonMgr::FindAddons: metadata.themoviedb.org.python v3.0.1 installed
2025-01-23 18:47:06.164 T:21657    info <general>: CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org v3.6.0 installed
2025-01-23 18:47:06.164 T:21657    info <general>: CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org.python v1.7.2 installed
2025-01-23 18:47:06.164 T:21657    info <general>: CAddonMgr::FindAddons: plugin.program.AML v1.0.2 installed
2025-01-23 18:47:06.165 T:21657    info <general>: CAddonMgr::FindAddons: plugin.program.openwizard v2.0.7 installed
2025-01-23 18:47:06.165 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.arteplussept v1.4.2 installed
2025-01-23 18:47:06.165 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.dailymotion_com v2.4.4 installed
2025-01-23 18:47:06.165 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.documentaryheaven v1.0.1+matrix.1 installed
2025-01-23 18:47:06.165 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.drnu v6.4.6 installed
2025-01-23 18:47:06.165 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.esa v1.3.0+matrix.1 installed
2025-01-23 18:47:06.166 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.filmarkivet v3.3.0+matrix.1 installed
2025-01-23 18:47:06.166 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.francetv v2.0.4+matrix.1 installed
2025-01-23 18:47:06.166 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.jellycon v0.8.0+py3 installed
2025-01-23 18:47:06.166 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.jellyfin v1.0.7+py3 installed
2025-01-23 18:47:06.166 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.nasa v3.0.3+matrix.1 installed
2025-01-23 18:47:06.166 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.netflix v1.23.3+matrix.1 installed
2025-01-23 18:47:06.167 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.nrk v4.8.0 installed
2025-01-23 18:47:06.167 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.retrospect v5.7.22 installed
2025-01-23 18:47:06.167 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.svtplay v5.1.21+matrix.1 installed
2025-01-23 18:47:06.167 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.vimeo v6.0.1 installed
2025-01-23 18:47:06.167 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.youtube v7.1.1.6 installed
2025-01-23 18:47:06.168 T:21657    info <general>: CAddonMgr::FindAddons: plugin.video.ytchannels v0.5.5+matrix.1 installed
2025-01-23 18:47:06.168 T:21657    info <general>: CAddonMgr::FindAddons: repository.castagnait v2.0.1 installed
2025-01-23 18:47:06.168 T:21657    info <general>: CAddonMgr::FindAddons: repository.jellyfin.kodi v1.0.0 installed
2025-01-23 18:47:06.168 T:21657    info <general>: CAddonMgr::FindAddons: repository.openwizard v2.0 installed
2025-01-23 18:47:06.168 T:21657    info <general>: CAddonMgr::FindAddons: repository.xbmc.org v3.3.1 installed
2025-01-23 18:47:06.168 T:21657    info <general>: CAddonMgr::FindAddons: resource.images.retrospect v1.0.21 installed
2025-01-23 18:47:06.169 T:21657    info <general>: CAddonMgr::FindAddons: resource.images.weathericons.default v1.1.9 installed
2025-01-23 18:47:06.169 T:21657    info <general>: CAddonMgr::FindAddons: resource.language.en_gb v2.0.2 installed
2025-01-23 18:47:06.169 T:21657    info <general>: CAddonMgr::FindAddons: resource.language.en_us v10.0.55 installed
2025-01-23 18:47:06.169 T:21657    info <general>: CAddonMgr::FindAddons: resource.uisounds.kodi v1.0.1 installed
2025-01-23 18:47:06.169 T:21657    info <general>: CAddonMgr::FindAddons: screensaver.xbmc.builtin.black v1.0.34 installed
2025-01-23 18:47:06.169 T:21657    info <general>: CAddonMgr::FindAddons: screensaver.xbmc.builtin.dim v1.0.66 installed
2025-01-23 18:47:06.170 T:21657    info <general>: CAddonMgr::FindAddons: script.common.plugin.cache v3.0.0 installed
2025-01-23 18:47:06.170 T:21657    info <general>: CAddonMgr::FindAddons: script.module.addon.signals v0.0.6+matrix.1 installed
2025-01-23 18:47:06.170 T:21657    info <general>: CAddonMgr::FindAddons: script.module.beautifulsoup4 v4.12.2 installed
2025-01-23 18:47:06.170 T:21657    info <general>: CAddonMgr::FindAddons: script.module.bossanova808 v1.0.0 installed
2025-01-23 18:47:06.170 T:21657    info <general>: CAddonMgr::FindAddons: script.module.certifi v2023.5.7 installed
2025-01-23 18:47:06.170 T:21657    info <general>: CAddonMgr::FindAddons: script.module.chardet v5.1.0 installed
2025-01-23 18:47:06.171 T:21657    info <general>: CAddonMgr::FindAddons: script.module.dateutil v2.8.2 installed
2025-01-23 18:47:06.171 T:21657    info <general>: CAddonMgr::FindAddons: script.module.dropbox v10.3.1+matrix.1 installed
2025-01-23 18:47:06.171 T:21657    info <general>: CAddonMgr::FindAddons: script.module.future v1.0.0+matrix.1 installed
2025-01-23 18:47:06.171 T:21657    info <general>: CAddonMgr::FindAddons: script.module.idna v3.4.0 installed
2025-01-23 18:47:06.171 T:21657    info <general>: CAddonMgr::FindAddons: script.module.inputstreamhelper v0.7.0 installed
2025-01-23 18:47:06.172 T:21657    info <general>: CAddonMgr::FindAddons: script.module.kodi-six v0.1.3.1 installed
2025-01-23 18:47:06.172 T:21657    info <general>: CAddonMgr::FindAddons: script.module.myconnpy v8.0.33 installed
2025-01-23 18:47:06.172 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pil v5.1.0 installed
2025-01-23 18:47:06.172 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pyaes v1.6.1+matrix.1 installed
2025-01-23 18:47:06.172 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pycryptodome v3.4.3 installed
2025-01-23 18:47:06.172 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pyjwt v2.8.0 installed
2025-01-23 18:47:06.173 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pyqrcode v1.2.1+matrix.4 installed
2025-01-23 18:47:06.173 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pyscrypt v1.6.2+matrix.1 installed
2025-01-23 18:47:06.173 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pysocks v1.7.0+matrix.1 installed
2025-01-23 18:47:06.173 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pysubs2 v1.5.0+matrix.1 installed
2025-01-23 18:47:06.173 T:21657    info <general>: CAddonMgr::FindAddons: script.module.pytz v2023.3.0+matrix.1 installed
2025-01-23 18:47:06.173 T:21657    info <general>: CAddonMgr::FindAddons: script.module.requests v2.31.0 installed
2025-01-23 18:47:06.174 T:21657    info <general>: CAddonMgr::FindAddons: script.module.requests-cache v0.5.2+matrix.2 installed
2025-01-23 18:47:06.174 T:21657    info <general>: CAddonMgr::FindAddons: script.module.routing v0.2.3+matrix.1 installed
2025-01-23 18:47:06.174 T:21657    info <general>: CAddonMgr::FindAddons: script.module.six v1.16.0+matrix.1 installed
2025-01-23 18:47:06.174 T:21657    info <general>: CAddonMgr::FindAddons: script.module.soupsieve v2.4.1 installed
2025-01-23 18:47:06.174 T:21657    info <general>: CAddonMgr::FindAddons: script.module.typing_extensions v4.7.1 installed
2025-01-23 18:47:06.174 T:21657    info <general>: CAddonMgr::FindAddons: script.module.urllib3 v2.1.0 installed
2025-01-23 18:47:06.175 T:21657    info <general>: CAddonMgr::FindAddons: script.module.websocket v1.6.4 installed
2025-01-23 18:47:06.175 T:21657    info <general>: CAddonMgr::FindAddons: script.module.xbmcswift2 v19.0.7 installed
2025-01-23 18:47:06.175 T:21657    info <general>: CAddonMgr::FindAddons: script.openweathermap.maps v1.0.6 installed
2025-01-23 18:47:06.175 T:21657    info <general>: CAddonMgr::FindAddons: script.speedtester v1.1.2+matrix.1 installed
2025-01-23 18:47:06.175 T:21657    info <general>: CAddonMgr::FindAddons: script.xbmc.lcdproc v4.1.0 installed
2025-01-23 18:47:06.175 T:21657    info <general>: CAddonMgr::FindAddons: script.xbmc.unpausejumpback v3.0.4 installed
2025-01-23 18:47:06.176 T:21657    info <general>: CAddonMgr::FindAddons: script.xbmcbackup v1.7.1 installed
2025-01-23 18:47:06.176 T:21657    info <general>: CAddonMgr::FindAddons: service.cronxbmc v0.1.7 installed
2025-01-23 18:47:06.176 T:21657    info <general>: CAddonMgr::FindAddons: service.subsmangler v2.2.0 installed
2025-01-23 18:47:06.176 T:21657    info <general>: CAddonMgr::FindAddons: service.subtitles.opensubtitles-com v1.0.5 installed
2025-01-23 18:47:06.176 T:21657    info <general>: CAddonMgr::FindAddons: service.xbmc.versioncheck v0.5.30+matrix.1 installed
2025-01-23 18:47:06.176 T:21657    info <general>: CAddonMgr::FindAddons: skin.estouchy v3.0.8 installed
2025-01-23 18:47:06.177 T:21657    info <general>: CAddonMgr::FindAddons: skin.estuary v3.0.10 installed
2025-01-23 18:47:06.177 T:21657    info <general>: CAddonMgr::FindAddons: weather.multi v0.0.27 installed
2025-01-23 18:47:06.177 T:21657    info <general>: CAddonMgr::FindAddons: webinterface.chorus v0.3.10 installed
2025-01-23 18:47:06.177 T:21657    info <general>: CAddonMgr::FindAddons: webinterface.default v19.x-2.4.8 installed
2025-01-23 18:47:06.177 T:21657    info <general>: CAddonMgr::FindAddons: xbmc.addon v20.5.0 installed
2025-01-23 18:47:06.177 T:21657    info <general>: CAddonMgr::FindAddons: xbmc.core v0.1.0 installed
2025-01-23 18:47:06.178 T:21657    info <general>: CAddonMgr::FindAddons: xbmc.gui v5.16.0 installed
2025-01-23 18:47:06.178 T:21657    info <general>: CAddonMgr::FindAddons: xbmc.json v13.0.0 installed
2025-01-23 18:47:06.178 T:21657    info <general>: CAddonMgr::FindAddons: xbmc.metadata v2.1.0 installed
2025-01-23 18:47:06.178 T:21657    info <general>: CAddonMgr::FindAddons: xbmc.python v3.0.1 installed
2025-01-23 18:47:06.178 T:21657    info <general>: CAddonMgr::FindAddons: xbmc.webinterface v1.0.0 installed
2025-01-23 18:47:06.183 T:21657    info <general>: Selected Logind/UPower as PowerSyscall
2025-01-23 18:47:06.183 T:21657   error <general>: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2025-01-23 18:47:06.183 T:21657    info <general>: LogindUPowerSyscall - UPower not found, battery information will not be available
2025-01-23 18:47:06.255 T:21657    info <general>: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
2025-01-23 18:47:06.383 T:21657    info <general>: RetroPlayer[RENDER]: Registering renderer factory for DMA
2025-01-23 18:47:06.383 T:21657    info <general>: RetroPlayer[RENDER]: Registering renderer factory for OpenGLES
2025-01-23 18:47:06.383 T:21657   error <general>: CDRMUtils::OpenDrm - no drm devices found: (No such file or directory)
2025-01-23 18:47:06.383 T:21657   error <general>: CWinSystemGbm::InitWindowSystem - failed to initialize Atomic DRM
2025-01-23 18:47:06.383 T:21657   error <general>: CWinSystemGbm::InitWindowSystem - failed to initialize Legacy DRM
2025-01-23 18:47:06.384 T:21657   error <general>: CDRMUtils::OpenDrm - no drm devices found: (No such file or directory)
2025-01-23 18:47:06.384 T:21657   error <general>: CWinSystemGbm::InitWindowSystem - failed to initialize off screen DRM
2025-01-23 18:47:06.863 T:21657 critical <general>: CApplication::CreateGUI - unable to init windowing system
2025-01-23 18:47:06.863 T:21657    info <general>: Stopping the application...
2025-01-23 18:47:06.864 T:21657    info <general>: Stopping player
2025-01-23 18:47:06.864 T:21657    info <general>: Storing total System Uptime
2025-01-23 18:47:06.864 T:21657    info <general>: Saving settings
2025-01-23 18:47:06.876 T:21657    info <general>: Saving skin settings
2025-01-23 18:47:06.876 T:21657    info <general>: Stopping all
2025-01-23 18:47:06.886 T:21657    info <general>: Application stopped
2025-01-23 18:47:07.029 T:21663    info <general>: Loading special://xbmc/system/Lircmap.xml
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'mceusb'
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'XboxDVDDongle'
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'Microsoft_Xbox'
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'PinnacleSysPCTVRemote'
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'anysee'
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'iMON-PAD'
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'Antec_Veris_RM200'
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'MCE_via_iMON'
2025-01-23 18:47:07.034 T:21663    info <general>: * Adding remote mapping for device 'TwinHanRemote'
2025-01-23 18:47:07.035 T:21663    info <general>: * Adding remote mapping for device 'linux-input-layer'
2025-01-23 18:47:07.035 T:21663    info <general>: * Linking remote mapping for 'linux-input-layer' to 'cx23885_remote'
2025-01-23 18:47:07.035 T:21663    info <general>: * Adding remote mapping for device 'mediacenter'
2025-01-23 18:47:07.035 T:21663    info <general>: * Adding remote mapping for device 'devinput'
2025-01-23 18:47:07.035 T:21663    info <general>: * Adding remote mapping for device 'devinput-32'
2025-01-23 18:47:07.035 T:21663    info <general>: * Adding remote mapping for device 'devinput-64'
2025-01-23 18:47:07.087 T:21657    info <general>: unload skin
2025-01-23 18:47:07.087 T:21657    info <general>: Unloaded skin
2025-01-23 18:47:07.087 T:21657    info <general>: unload sections
2025-01-23 18:47:07.088 T:21657    info <general>: CWSDiscoveryListenerUDP::Stop - Stopped
Any ideas anyone? Would be very grateful
Forgot to say that Kodi cannot be started from inside LXDE either.
Tried reinstalling Pipewire and uninstall it. Same with conflict with Pulseaudio, a solution i found online but same results, checked that the displaydrivers are working. It seems they are. X/LXDE working perfectly.
I SOLVED IT!
When I installed Moonlight Streaming client something must have changed the way Kodi uses the graphics subsystem. I went into dietpi-config and checked under “display options”. There I saw that “18 : RPi Codecs : [On] V4L2 hardware video codecs” was ON. I tried to switch it off and reboot and VOILÁ, it all worked.
The pipewire error message is still there however but it does not affect anything it seems.
