Problems installing Open JDK 17
I’m having trouble installing the “openjdk-17-jdk-headless” package via apt on the current DietPi. What would be the easiest way to install Java 17? I would like to install and test the “Thingsboard” software, but it requires Java 17. I tried openjdk-21 and it does not work.
I get the message:
Error: Package openjdk-17-jdk-headless cannot be found.
Do I need to add another repo or adjust a configuration somewhere so I can access a different Debian repo?
Thank you in advance.
You could have started to fill the troubleshooting template
You are right, sorry, this was my mistake. I thought everything important was in my text, I spent several hours today searching for solutions on google, but unfortunately I couldn’t find any so far
    G_DIETPI_VERSION_SUB=17
    G_DIETPI_VERSION_RC=2
  • Distro version | trixie
  • Kernel version | Linux 6.12.48+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.48-1 (2025-09-20) x86_64 GNU/Linux
  • Architecture | amd64
  • SBC model | - VM
  • Power supply used | - VM
  • SD card used | - VM
  • Software title | ThingsBoard
  • i tried to install Thingsboard which needs Java 17 as a dependency
  • Can this issue be replicated on a fresh installation of DietPi? → yes
<!-- Explain how to reproduce the issue -->
  1. apt install openjdk-17-jdk-headless
<!-- What SHOULD be happening? -->
  • openjdk 17 gets installed…
<!-- What IS happening? -->
  • Error Message: Fehler: Paket openjdk-17-jdk-headless kann nicht gefunden werden.
<!-- Please post any extra details that might help solve the issue -->
The package you are trying to install is not available anymore in debian trixie https://packages.debian.org/search?suite=trixie&arch=any&searchon=names&keywords=openjdk
You would need to install version 21 or 25 or if you explicitly need version 17, build it by yourself.
But I guess it should be compatible with version 21 too.
dietpi-software install 8
not necessarily, the alternative would be adoptium JFrog
Similar we do as well
Thank you very much!
this guide helped me:
at the end i was able to install with:
“apt install temurin-17-jdk”
and now i can install and configure ThingsBoard (and start it / open the WebUI)
