- DietPi version |
cat /boot/dietpi/.version - Distro version |
echo $G_DISTRO_NAME $G_RASPBIAN - Kernel version |
uname --all - Architecture |
dpkg --print-architecture - SBC model |
echo $G_HW_MODEL_NAMEor (EG: RPi3) - Power supply used | (EG: 5V 1A RAVpower)
- SD card used | (EG: SanDisk ultra)
← If you sent a “dietpi-bugreport”, please paste the ID here → - Bug report ID |
echo $G_HW_UUID
Try to play music:dietpi@DietPi-Odroid:~$ pw-dsdplay -vd /mnt/dietpi_userdata/Music/Musik-SD-Karte/dsd-testfiles/03\ -\ \(David\ Elias\)\ Morning\ Light\ \ Western\ Town.dsf
dsffile: opened file "/mnt/dietpi_userdata/Music/Musik-SD-Karte/dsd-testfiles/03 - (David Elias) Morning Light Western Town.dsf" channels:2 rate:2822400 samples:1014136832 bitorder:lsb
rate:0 latency:0 (0,000s)
connecting playback stream; target=(null)
stream state changed unconnected -> connecting
stream param change: Spa:Enum:ParamId:Latency
stream param change: Spa:Enum:ParamId:Tag
stream properties:
application.name = "pw-dsdplay"
node.name = "pw-dsdplay"
media.type = "Audio"
media.category = "Playback"
media.role = "Music"
media.filename = "/mnt/dietpi_userdata/Music/Musik-SD-Karte/dsd-testfiles/03 - (David Elias) Morning Light Western Town.dsf"
media.name = "/mnt/dietpi_userdata/Music/Musik-SD-Karte/dsd-testfiles/03 - (David Elias) Morning Light Western Town.dsf"
stream.is-live = "true"
node.want-driver = "true"
node.autoconnect = "true"
node.loop.class = "main"
node.async = "true"
media.class = "Stream/Output/Audio"
remote 0 is named "pipewire-0"
stream state changed connecting -> paused...
Music ist playing.;)- …
No music is playing.- …
I've tried two DACs: iFi Zen DAC V2 and Topping D10s. No problem on Linux Mint 22.2. But no chance to play DSD with the Odroid N2 and dietpi.- …
paste lines of logs or code into such code fences here
