Problem with migration from Rpi to PC
Hello, I start migration from Rpi4(32bit) to Mini PC(64bit). I have connected to Rpi usb HDD where dietpi_userdata is. I have Emby Server and Nextcloud installed there with SSL certyficate.
I use Emby Premiere and backup/restore plugin do the job. Emby works after migration on local IP. Nextcloud and SSL don’t.
First I move /etc/letsencrypt folder to new Dietpi installation but that don’t work. Second I remove /etc/letsencrypt folder and install dietpi-letsencrypt from beginning but also don’t work. I paste wright credentials from no-ip because it see domain name. I edit in my router config openports IP to new one from Mini PC and reload router.
I connect usb HDD and mount old dietpi_userdata on new Mini PC. I use nextcloud migration-script https://dietpi.com/forum/t/owncloud-nextcloud-migration-script-for-v6-0-update/1867/6 and save backup on another HDD. First time I don’t create backup folder so script leave nextcloud_data in dietpi_userdata. I run second time and it copy nextcloud_data to backup folder. Script won’t run as dietpi user or root when I chmod -x like in tutorial so I add chmod 777. Script run OK then.
When I install nextcloud it don’t install wright because have some problem with database like in pastebin here https://pastebin.com/1DAb8SJJ.
Now I have blank page with that when I try to enter my nextcloud:
https://mojserver.ddns.net/nextcloud/
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.
that page when I try https://mojserver.ddns.net
Placeholder page
The owner of this web site has not put up any web pages yet. Please come back later.
You should replace this page with your own web pages as soon as possible.
Unless you changed its configuration, your new server is configured as follows:
Configuration files can be found in /etc/lighttpd. Please read /etc/lighttpd/conf-available/README file.
The DocumentRoot, which is the directory under which all your HTML files should exist, is set to /var/www/html.
CGI scripts are looked for in /usr/lib/cgi-bin, which is where Debian packages will place their scripts. You can enable cgi module by using command "lighty-enable-mod cgi".
Log files are placed in /var/log/lighttpd, and will be rotated weekly. The frequency of rotation can be easily changed by editing /etc/logrotate.d/lighttpd.
The default directory index is index.html, meaning that requests for a directory /foo/bar/ will give the contents of the file /var/www/html/foo/bar/index.html if it exists (assuming that /var/www/html is your DocumentRoot).
You can enable user directories by using command "lighty-enable-mod userdir"
About this page
This is a placeholder page installed by the Debian release of the Lighttpd server package.
This computer has installed the Debian GNU/Linux operating system, but it has nothing to do with the Debian Project. Please do not contact the Debian Project about it.
If you find a bug in this Lighttpd package, or in Lighttpd itself, please file a bug report on it. Instructions on doing this, and the list of known bugs of this package, can be found in the Debian Bug Tracking System.
and when I try https Emby it shows error :ERR_SSL_PROTOCOL_ERROR
I don’t have idea what I can do? How to fix this. Please help.
Regards,
Przemko
looks like access issues from web sever to database
Access denied for user 'oc_admin'@'localhost'
You could try to set a new password. First check actual password on NC config
root@DietPi:~# cat /var/www/nextcloud/config/config.php | grep dbpassword
  'dbpassword' => 'topsecret',
And set this password to on database level
mysql -u root -e "SET PASSWORD FOR 'oc_admin'@localhost = PASSWORD(\"topsecret\");"
dietpi-services restart
[/quote]
Yes, I have wrong password. But when I paste that password to taht command I have error:
ERROR 1133 (28000) at line 1: Can't find any matching row in the user table
Regards.
probably installation did not finished correctly and user did not get created. You could check users on MariaDB
mysql -e "SELECT User, Host FROM mysql.user;"
I have that nice output:
| User | Host      |
| root | localhost |
I fix Emby SSL folder permissions and Emby works on https so letsencrypt is OK.
Regards.
well NC data base user was not created. Therefore NC is not working. You can check available databases
mysql -e "SHOW DATABASES;"
| Database           |
| information_schema |
| mysql              |
| nextcloud          |
| performance_schema
I see errors when installing nextcloud that oc_admin don’t have permissions. I see similar thread here: php - SQLSTATE[HY000] [1698] Access denied for user 'root'@'localhost' - Stack Overflow
Do You think I can use something like this?
GRANT ALL PRIVILEGES ON . TO ‘oc_admin’@‘localhost’;
FLUSH PRIVILEGES;
you can try to create the user oc_admin
mysql -e "grant all privileges on nextcloud.* TO 'oc_admin'@'%' identified by \"topsecret\";"
But not sure if this will fix your issue, as installation did not succeed if I’m not mistaken.
I try that also with another password from nextcloud migration script gave me at the end but don’t help. When reinstall nextcloud I have that output:
An unhandled exception has been thrown:
PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:78
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php(78): PDO->query('SELECT * FROM `...')
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(911): Doctrine\DBAL\Driver\PDOConnection->query('SELECT * FROM `...')
#2 /var/www/nextcloud/lib/private/DB/Connection.php(202): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM `...', Array, Array, NULL)
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): OC\DB\Connection->executeQuery('SELECT * FROM `...', Array, Array)
#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(217): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#7 /var/www/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#8 /var/www/nextcloud/lib/private/legacy/OC_App.php(949): OC\AppConfig->getValues(false, 'installed_versi...')
#9 /var/www/nextcloud/lib/private/Server.php(668): OC_App::getAppVersions()
#10 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#11 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#12 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#13 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', true)
#14 /var/www/nextcloud/lib/private/Server.php(1677): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#15 /var/www/nextcloud/lib/private/Server.php(1017): OC\Server->getMemCacheFactory()
#16 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#17 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#18 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#19 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', true)
#20 /var/www/nextcloud/lib/private/Server.php(1977): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#21 /var/www/nextcloud/lib/private/Files/View.php(118): OC\Server->getLockingProvider()
#22 /var/www/nextcloud/lib/private/Server.php(395): OC\Files\View->__construct()
#23 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#24 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#25 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#26 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', true)
#27 /var/www/nextcloud/lib/private/Server.php(1324): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#28 /var/www/nextcloud/lib/base.php(595): OC\Server->boot()
#29 /var/www/nextcloud/lib/base.php(1091): OC::init()
#30 /var/www/nextcloud/console.php(49): require_once('/var/www/nextcl...')
#31 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#32 {main}
Next Doctrine\DBAL\Driver\PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:83
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(911): Doctrine\DBAL\Driver\PDOConnection->query('SELECT * FROM `...')
#1 /var/www/nextcloud/lib/private/DB/Connection.php(202): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM `...', Array, Array, NULL)
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): OC\DB\Connection->executeQuery('SELECT * FROM `...', Array, Array)
#3 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(217): Doctrine\DBAL\Query\QueryBuilder->execute()
#4 /var/www/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#5 /var/www/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#6 /var/www/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#7 /var/www/nextcloud/lib/private/legacy/OC_App.php(949): OC\AppConfig->getValues(false, 'installed_versi...')
#8 /var/www/nextcloud/lib/private/Server.php(668): OC_App::getAppVersions()
#9 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#10 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#11 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#12 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', true)
#13 /var/www/nextcloud/lib/private/Server.php(1677): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#14 /var/www/nextcloud/lib/private/Server.php(1017): OC\Server->getMemCacheFactory()
#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#16 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#17 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#18 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', true)
#19 /var/www/nextcloud/lib/private/Server.php(1977): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#20 /var/www/nextcloud/lib/private/Files/View.php(118): OC\Server->getLockingProvider()
#21 /var/www/nextcloud/lib/private/Server.php(395): OC\Files\View->__construct()
#22 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#23 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#24 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#25 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', true)
#26 /var/www/nextcloud/lib/private/Server.php(1324): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#27 /var/www/nextcloud/lib/base.php(595): OC\Server->boot()
#28 /var/www/nextcloud/lib/base.php(1091): OC::init()
#29 /var/www/nextcloud/console.php(49): require_once('/var/www/nextcl...')
#30 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#31 {main}
Next Doctrine\DBAL\Exception\TableNotFoundException: An exception occurred while executing 'SELECT * FROM `oc_appconfig`':
SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php:42
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(169): Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\DBAL\Driver\PDOException))
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(149): Doctrine\DBAL\DBALException::wrapException(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Driver\PDOException), 'An exception oc...')
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(914): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Driver\PDOException), 'SELECT * FROM `...', Array)
#3 /var/www/nextcloud/lib/private/DB/Connection.php(202): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM `...', Array, Array, NULL)
#4 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): OC\DB\Connection->executeQuery('SELECT * FROM `...', Array, Array)
#5 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(217): Doctrine\DBAL\Query\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#7 /var/www/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#8 /var/www/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#9 /var/www/nextcloud/lib/private/legacy/OC_App.php(949): OC\AppConfig->getValues(false, 'installed_versi...')
#10 /var/www/nextcloud/lib/private/Server.php(668): OC_App::getAppVersions()
#11 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#12 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#13 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#14 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', true)
#15 /var/www/nextcloud/lib/private/Server.php(1677): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#16 /var/www/nextcloud/lib/private/Server.php(1017): OC\Server->getMemCacheFactory()
#17 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#18 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#19 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#20 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', true)
#21 /var/www/nextcloud/lib/private/Server.php(1977): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#22 /var/www/nextcloud/lib/private/Files/View.php(118): OC\Server->getLockingProvider()
#23 /var/www/nextcloud/lib/private/Server.php(395): OC\Files\View->__construct()
#24 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#25 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#26 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#27 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', true)
#28 /var/www/nextcloud/lib/private/Server.php(1324): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#29 /var/www/nextcloud/lib/base.php(595): OC\Server->boot()
#30 /var/www/nextcloud/lib/base.php(1091): OC::init()
#31 /var/www/nextcloud/console.php(49): require_once('/var/www/nextcl...')
#32 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#33 {main}An unhandled exception has been thrown:
Stack trace:
#32 {main}
Stack trace:
#31 {main}
Stack trace:
Stack trace:
#32 {main}
Stack trace:
#31 {main}
Stack trace:
Stack trace:
#32 {main}
Stack trace:
#31 {main}
Stack trace:
now you are missing all the tables inside the database
Probably better to perform a clean empty NC installation and restore your data later on
Joulinar I will do that but can You tell me what steps I have to make?
  1. Remove nextcloud with dietpi-software.
  2. Remove /var/www/nextcloud folder if it will be there.
  3. Move /dietpi_userdata/nextcloud_data to external hdd.
  4. Clean install of nextcloud.
  5. ?
    Can You help me with that? Is that correct steps and what to do next?
    Regards.
    Przemek.
  1. Move /dietpi_userdata/nextcloud_data to external hdd
  2. Remove Nextcloud + MariaDB with dietpi-software
  3. rm -Rf /var/www/nextcloud /mnt/dietpi_userdata/nextcloud_data
  4. rm -Rf /{mnt/dietpi_userdata,var/lib,var/log,etc}/mysql
  5. Clean install of Nextcloud
This should give you an empty NC installation
When I make clean installation,how to restore my old nextcloud config and data? Move backed folder nextcloud_data to /mnt/dietpi_userdata?
Regards,
Przemek
Hi Joulinar I make clean install like You said and then copy backup of /dietpi_userdata/nextcloud_data to /dietpi_userdata and now I see nextcloud login screen but cannot login. Wrong user or password or when I try with https I see error: Too many attepmpts from my IP.
Regards.
did you tried using the default password?
User: admin
PW: global application password
I use that and it works but I don’t have my settings and users. I try to add my old user with old password but that don’t work. I have bad request error.
Regards.
you would need to restore the database backup you have done on the old system
Joulinar Thanks for Your help. I have only 3 users. I have my files and I will make those 3 users with new names and new passwords. I don’t won’t to struggle with that database because I need nextcloud to my work tomorrow.
Regards and thanks.
Nextcloud allow you to scan your files system for new added files, if you have copied them in place
ncc files:scan --all
I have info that my new users folders are not writable. Can You tell me also If I change owner of:
-rw-r--r--   1 root     root          1292 mar  7 18:51 dietpi-nextcloud-database-backup.sql
to www-data it could work to restore database?
Regards.
