After apparently a succesfull update process from v.150 to v.152 in my RPI 2 reboot command is not recognized.
In fact no command works, so I have to unplug the device.
But after booting, no version change. It indicates v.150 and there is a message for the update. If I run dietpi-update one more time I get same result: no reboot command available and no update.
Its a loop. ![:frowning: :frowning:](/forum/images/emoji/twitter/frowning.png?v=12)
As we cant replicate this our end, most likely a filesystem corruption due to unstable hardware.
Can you please verify sufficient:
- SD card (eg: Sandisk ultra)
- PSU (eg: Official RPi PSU 5v/2A)
I would recommend starting from a fresh DietPi image.
Im using a compatible SD card. I have had no problems for ages with it. Its fast as needed and reliable.
Im using Official RPi PSU 5v/2A.
Starting a new installation …
![:neutral_face: :neutral_face:](/forum/images/emoji/twitter/neutral_face.png?v=12)
