Problem: Module zfs not found in directory /lib/modules/6.12.47+rpt-rpi-v8
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=17
G_DIETPI_VERSION_RC=2
G_LIVE_PATCH_STATUS\[0\]=‘not applicable’
bookworm 0
Linux Nasbeery 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1\~bookworm (2025-09-16) aarch64 GNU/Linux
dietpi@Nasbeery:\~$ dpkg --print-architecture
arm64
dietpi@Nasbeery:\~$ echo $G_HW_MODEL_NAME
RPi 4 Model B (aarch64)
Updated from 9.14.2 to v9.16.3
Failed to start zfs-load-module.service - Install ZFS kernel module.
zfs-load-module.service: Failed with result ‘exit-code’.
zfs-load-module.service: Main process exited, code=exited, status=1/FAILURE
modprobe: FATAL: Module zfs not found in directory /lib/modules/6.12.47+rpt-rpi-v8
Starting zfs-load-module.service - Install ZFS kernel module…
Pls fill the form
Required
  • Kernel version | uname -a
  • SBC model | echo $G_HW_MODEL_NAME
updated infos above
Did you check this thread:
https://dietpi.com/forum/t/solved-zfs-support-in-dietpi/22118/15
thanks, it doesn’t helped. Now I figured out:
my solution for rpi4 was:
uname -r
apt search linux-headers-$(uname -r)
apt search linux-headers-6.12.47
sudo apt install dkms
sudo dkms autoinstall
sudo apt install linux-headers-6.12.47+rpt-rpi-v8
sudo apt install dkms linux-headers-$(uname -r)
sudo apt install --reinstall zfs-dkms
sudo apt install zfs-dkms zfsutils-linux zfs-zed
At best install the headers meta package instead of the versioned one. Else you need to install new headers on every kernel upgrade manually:
apt install linux-headers-rpi-v8
That one depends on the respective latest versioned one, like linux-image-rpi-v8 does. So whenever the kernel is upgraded, the headers are as well, and DKMS can compile the new ZFS module right away.
