The following packages have unmet dependencies:
cpp-12 : Depends: libmpc3 (>= 1.1.0) but it is not going to be installed
Depends: libmpfr6 (>= 3.1.3) but it is not installable
xserver-xorg-core : Depends: libunwind8 but it is not installable
### Creating a bug report/issue
[] I have searched the existing open and closed issues
#### Required Information
- DietPi version | `cat /boot/dietpi/.version`
- Distro version | `echo $G_DISTRO_NAME $G_RASPBIAN`
- Kernel version | `uname --all`
- Architecture | `dpkg --print-architecture`
- SBC model | `echo $G_HW_MODEL_NAME` or (EG: RPi3)
- Power supply used | (EG: 5V 1A RAVpower)
- SD card used | (EG: SanDisk ultra)
#### Additional Information (if applicable)
<-- If you sent a "dietpi-bugreport", please paste the ID here -->
- Bug report ID | `echo $G_HW_UUID`
#### Steps to reproduce
<!-- Explain how to reproduce the issue -->
1. ...
2. ...
#### Expected behaviour
<!-- What SHOULD be happening? -->
#### Actual behaviour
<!-- What IS happening? -->
#### Extra details
<!-- Please post any extra details that might help solve the issue -->
apt update
apt install libmpc3
The following information may help to resolve the situation:
libmpc3 : Depends: libmpfr6 (>= 4.0.0) but it is not installable
E: Unable to correct problems, you have held broken packages.
apt show libmpfr6
Package: libmpfr6
State: not a real package (virtual)
N: Can't select candidate version from package libmpfr6 as it has no candidate
N: There is 1 additional record. Please use the '-a' switch to see it
N: No packages found
for i in /etc/apt/preferences{,.d/*}
do
[[ -f "$i" ]] || continue
echo "$i:"
cat "$i"
done
/etc/apt/preferences.d/apt-listbugs:
Explanation: Pinned by apt-listbugs at 2024-06-30 08:53:37 +0100
Explanation: #1057355: libmpfr6: major formatted output function bugs with %c and the value 0
Package: libmpfr6
Pin: version *
Pin-Priority: -30000
Explanation: #994510: libunwind8 abuses setcontext() causing SIGSEGV on i386 with glibc >= 2.32
Package: libunwind8
Pin: version *
