Problem installing Docker (package 162) after 9.13.2
  • DietPi version :
    G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=13
    G_DIETPI_VERSION_RC=2
  • Distro version : bookworm
  • Kernel version : Linux vault 6.12.23-current-sunxi64 #1 SMP Thu Apr 10 12:39:41 UTC 2025 aarch64 GNU/Linux
  • Architecture : arm64
  • SBC model : Orange Pi Zero 3 (aarch64)
  • Power supply used : Chicony 3.0A 15.0W
  • SD card used : SanDisk ultra
  • Software title : Docker (package 162) but also Docker Compose (134)
    Clean installation (but after some more digging it also not works via dietpi.txt)
    Yes
  1. do a clean installation
  2. after completing run:
    dietpi-software install 162
Docker should be installed
Docker doesn’t install. Get the following error in a windows pop-up :
Checking URL: download.docker com/linux/debian bookworm/gpg
- Command: curl -ILfvm 10 https // download docker com/linux/debian bookworm/gpg
- Exit code: 3
- DietPi version: v9.13.2 (MichaIng/master) | HW_MODEL: 83 | HW_ARCH: 3 | DISTRO: 7
- Error log:
* Closing connection -1
curl: (3) URL using bad/illegal format or missing URL
If I choose change command I get the following :
curl -ILfvm 10 http$://download.docker.com/linux/debian bookworm/gpg`
I changed the s into a $ because the forum thinks I want to add a link :grin:
This URL doesn’t exist.
Running the curl command gives:
* Connection #0 to host download docker com left intact
* Could not resolve host: bookworm
* Closing connection 1
curl: (6) Could not resolve host: bookworm
Have been testing some Orange Pi boards the last couple of days with automated installation (dietpi.txt) without any issues, till today. Clean install on 2 boards hung, after manual intervention it appeared that Docker wan’t installed and am unable to do it via Dietpi-software. Hence this Topic.
Better to use code sections :wink:
Pls change the URL to
https://download.docker.com/linux/debian/gpg
This would need to be done twice
Thanks. First time post on the forum :blush:
I adjusted the URL via change command and indeed (after 2 changes) it now installs.
Any idea how I can change it so automated installs (dietpi.txt) also install correctly ??
Regards
you could need to adjust dietpi-software script :wink: or wait on us to provide a fix.
