Problem after Nexcloud update to ver 32
  • DietPi version |
  • G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=19
    G_DIETPI_VERSION_RC=2
  • Distro version | bookworm 0
  • Kernel version | Linux DietPiNC 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookworm (2025-09-16) aarch64 GNU/Linux
  • Architecture | arm64
  • SBC model | RPi 5 Model B (aarch64)
  • Power supply used | (EG: 5V 3A RAVpower)
  • SD card used | (???)
Additional Information
  • Today I got a message in Nextcloud to update to ver 32. I started this by using the updater in Nextcloud gui. Everything went well untill I had to press the button for browser update.
  • Now the misery takes over the system.The update process endet without warnings or other messages and from this moment the nextcloud wasn´t accessible until now.
  • The Desktop client says Nextcloud is offline, when I try to start Nextcloud in my browser, I get the message “This page isn´t working at the moment….. HTTP ERROR 500.
    Even after several reboots of the PI Nextcloud won´t work. Neither if I try to access it locally nor via its Dyndns webaddress.
    I´ve already ckecked the maintenance flag in config.php which says maintenance=false
    I´v also checked that all data ist still present on disk(nvme) as well as the backup data on a secondary usb sata drive.
    Just Nextcloud won´t work at the moment.
    Do You have any hint how to get my Nextcloud back working?
    Sorry for my bad English, I tried my very best ;.)
first it would be good to know what failed, you can have a look here:
grep 2025-11 /mnt/dietpi_userdata/nextcloud_data/updater.log
If it was already december when you tried the update, change the command to 2025-12.
What webserver do you use? There are probably also some hints about the HTTP 500 in its logs.
what is the status of your services
dietpi-services status
Hello Jappe,
thanks for your fast response.
The following I could find out:
  1. I updated to ver 31.0.11.2 earlier that day the log is a little different to the update log to 32.0.2
    • 32.0.2 ends with the lines
2025-11-30T22:39:36+0000 roz6mrIdyy \[info\] startStep(“12”)
2025-11-30T22:39:36+0000 roz6mrIdyy \[info\] finalize()
2025-11-30T22:39:36+0000 roz6mrIdyy \[info\] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/nextcloud/
2025-11-30T22:39:36+0000 roz6mrIdyy \[info\] call opcache_reset()
2025-11-30T22:39:36+0000 roz6mrIdyy \[info\] end of finalize()
2025-11-30T22:39:36+0000 roz6mrIdyy \[info\] endStep(“12”)
  • 31.0.11.2 Has some more lines after endStep (“12”)
  2025-11-30T22:31:54+0000 CtAPram2Dl \[info\] end of finalize()
  2025-11-30T22:31:54+0000 CtAPram2Dl \[info\] endStep(“12”)
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] request to updater
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] currentStep()
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] show HTML page
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] current version: 31.0.11 build time: 2025-11-20T10:02:59+00:00 b883fe276498a48863b61cdaaaca5eb51823504f
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] getUpdateServerResponse()
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] updaterServer: https://updates.nextcloud.com/updater_server/
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] releaseChannel: stable
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] internal version: 31.0.11.2
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] updateURL: https://updates.nextcloud.com/updater_server/?version=31x0x11x2xxxstablexx2025-11-20T10%3A02%3A59%2B00%3A00+b883fe276498a48863b61cdaaaca5eb51823504fx8x2x29
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] getUpdateServerResponse response: Array
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] checkForUpdate() Array
  2025-11-30T22:38:08+0000 eXOZbRqHGK \[info\] getChangelogURL()
I don´t know if these additional lines may be the problem.
I think I installed Apache as webserver (standard dietpi Nextcloud installation routine)
@Joulinar
the command shows this result:
DietPi-Services
Mode: status
\[  OK  \] DietPi-Services | redis-server         active (running) since Mon 2025-12-01 01:21:16 CET; 8h ago
\[  OK  \] DietPi-Services | mariadb              active (running) since Mon 2025-12-01 01:21:17 CET; 8h ago
\[  OK  \] DietPi-Services | php8.2-fpm           active (running) since Mon 2025-12-01 01:21:19 CET; 8h ago
\[  OK  \] DietPi-Services | apache2              active (running) since Mon 2025-12-01 01:21:19 CET; 8h ago
\[  OK  \] DietPi-Services | cron                 active (running) since Mon 2025-12-01 01:21:17 CET; 8h ago
\[  OK  \] DietPi-Services | dropbear             active (running) since Mon 2025-12-01 01:21:16 CET; 8h ago
\[  OK  \] DietPi-Services | vncserver            active (exited) since Mon 2025-12-01 01:21:16 CET; 8h ago
\[ INFO \] DietPi-Services | dietpi-vpn           inactive (dead)
\[ INFO \] DietPi-Services | dietpi-cloudshell    inactive (dead)
\[  OK  \] DietPi-Services | dietpi-ramlog        active (exited) since Mon 2025-12-01 01:21:07 CET; 8h ago
\[  OK  \] DietPi-Services | dietpi-preboot       active (exited) since Mon 2025-12-01 01:21:08 CET; 8h ago
\[  OK  \] DietPi-Services | dietpi-postboot      active (exited) since Mon 2025-12-01 01:21:16 CET; 8h ago
\[ INFO \] DietPi-Services | dietpi-wifi-monitor  inactive (dead)
Any ideas, I don´t have one :frowning:
I don’t think so, they appear several minutes after the update, maybe some NC app updates.
For me it looks like the update process was successful.
Do you have only nextcloud running? If not, are other web apps also affected?
And you can check the apache logs:
sudo journalctl -u apache2
Dez 01 01:21:19 DietPiNC systemd\[1\]: Starting apache2.service - The Apache HTTP Server…
Dez 01 01:21:19 DietPiNC systemd\[1\]: Started apache2.service - The Apache HTTP Server.
Dez 01 01:21:28 DietPiNC apache2\[865\]: \[proxy_fcgi:error\] \[pid 865:tid 868\] \[client 84.184.254.122:62451\] AH01071: Got error ‘PHP message: PHP Fatal error:  Class OCA\\GroupFolders\\Versions\\VersionsBackend contains 1 abstract method and must therefore be declared abstract or implement the remaining methods (OCA\\Files_Versions\\Versions\\IVersionBackend::getRevision) in /var/www/nextcloud/apps/groupfolders/lib/Versions/VersionsBackend.php on line 40’
Dez 01 01:21:28 DietPiNC apache2\[865\]: \[proxy_fcgi:error\] \[pid 865:tid 867\] \[client 84.184.254.122:64395\] AH01071: Got error ‘PHP message: PHP Fatal error:  Class OCA\\GroupFolders\\Versions\\VersionsBackend contains 1 abstract method and must therefore be declared abstract or implement the remaining methods (OCA\\Files_Versions\\Versions\\IVersionBackend::getRevision) in /var/www/nextcloud/apps/groupfolders/lib/Versions/VersionsBackend.php on line 40’
Dez 01 01:22:28 DietPiNC apache2\[865\]: \[proxy_fcgi:error\] \[pid 865:tid 873\] \[client 84.184.254.122:60025\] AH01071: Got error ‘PHP message: PHP Fatal error:  Class OCA\\GroupFolders\\Versions\\VersionsBackend contains 1 abstract method and must therefore be declared abstract or implement the remaining methods (OCA\\Files_Versions\\Versions\\IVersionBackend::getRevision) in /var/www/nextcloud/apps/groupfolders/lib/Versions/VersionsBackend.php on line 40’
…and so on, this apache proxy fcgi error occours every few minutes until now.
On this PI Nextcloud is the main application and its dedicated just for all processes Nextcloud is depending on
It looks like the group folders/ team folders app updated itself and failed, see
https://github.com/nextcloud/groupfolders/issues/4037
and
https://help.nextcloud.com/t/fatal-php-error-nach-upgrade-auf-nc32-linuxserver-io/233261
Can you check
ncc app:list | grep groupfolders
Thats the result of your command:
“Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
  • groupfolders: 19.1.10”
can you tell me the command?
There are som commands noticed at this Linke above, but I can´t exactly figure out which one will work for my Problem, sorry :frowning:
I’m also not so sure, bc the problem should arise with the update to groupfolders 20.1. but your are still on 19.1.10.
Hm can you try
ncc app:update --all
I´ve entered the Command
The following message appeared:
PHP Fatal error: Class OCA\GroupFolders\Versions\VersionsBackend contains 1 abstract method and must therefore be declared abstract or implement the remaining methods (OCA\Files_Versions\Versions\IVersionBackend::getRevision) in /var/www/nextcloud/apps/groupfolders/lib/Versions/VersionsBackend.php on line 40
Question: I´m always reading a “PHP Fatal error” message. Might I possibly need al later version of php?
php -version says
PHP 8.2.29 (cli) (built: Jul 3 2025 16:16:05) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.29, Copyright (c) Zend Technologies
with Zend OPcache v8.2.29, Copyright (c), by Zend Technologies
By the way, here are the versions of
Apache2: Server version: Apache/2.4.65 (Debian)
MariaDB: mariadb Ver 15.1 Distrib 10.11.14-MariaDB, for debian-linux-gnu (aarch64) using EditLine wrapper
If this information will help
No, PHP 8.2 is fine for NC 32, 8.1 is still supported but deprected tho
https://docs.nextcloud.com/server/stable/admin_manual/release_notes/upgrade_to_32.html
TThe problem is within nextclouds php code.
@MichaIng we need your help
Hmm there were some bugs with the group folders app when NC32 was released, but they have been fixed and it works happily with NC32 and PHP 8.4 on the NC instance we use DietPi-internally. Ah yeah this was with v20 of the app, weird that you are on v19 which is probably incompatible expectedly.
Looks like this: Cant use nextcloud while groupfolders is enabled · Issue #4169 · nextcloud/groupfolders · GitHub
An app name change? I did not recognize, will have a closer look when back home.
@jochem
Csn you check the updater.log again whether you see an update attempt for the groupfolders app? This should be done automatically as part of the Nextcloud update, but obviously it was not done, or failed without causing an updater error, at least.
I must apologize; with all the problems with Nextcloud, I forgot to mention that I manually updated the team folders before running the two Nextcloud updates with the updater on November 30.
After the teamfolders update and the following update to nextcloud 31.0.11.2 everything worked well.
Here is the full updater log:
Zusammenfassung
Zusammenfassung
root@DietPiNC:~# grep 2025-11 /mnt/dietpi_userdata/nextcloud_data/updater.log
2025-11-30T22:19:06+0000 1covfjzEZh [info] request to updater
2025-11-30T22:19:06+0000 1covfjzEZh [info] currentStep()
2025-11-30T22:19:06+0000 1covfjzEZh [info] show HTML page
2025-11-30T22:19:06+0000 1covfjzEZh [info] current version: 31.0.4 build time: 2025-04-17T09:09:41+00:00 f3ea37085207b00904ae08faed2acec8c12d0774
2025-11-30T22:19:06+0000 1covfjzEZh [info] getUpdateServerResponse()
2025-11-30T22:19:06+0000 1covfjzEZh [info] updaterServer: https://updates.nextcloud.com/updater_server/
2025-11-30T22:19:06+0000 1covfjzEZh [info] releaseChannel: stable
2025-11-30T22:19:06+0000 1covfjzEZh [info] internal version: 31.0.4.1
2025-11-30T22:19:06+0000 1covfjzEZh [info] updateURL: https://updates.nextcloud.com/updater_server/?version=31x0x4x1xxxstablexx2025-04-17T09%3A09%3A41%2B00%3A00+f3ea37085207b00904ae08faed2acec8c12d0774x8x2x29
2025-11-30T22:19:06+0000 1covfjzEZh [info] getUpdateServerResponse response: Array
2025-11-30T22:19:06+0000 1covfjzEZh [info] checkForUpdate() Array
2025-11-30T22:19:06+0000 1covfjzEZh [info] getChangelogURL()
2025-11-30T22:19:06+0000 1covfjzEZh [info] end of checkForUpdate() Update to Nextcloud 31.0.11 available. (channel: “stable”)Following file will be downloaded automatically: https://download.nextcloud.com/server/releases/nextcloud-31.0.11.zipOpen changelog :up_right_arrow:
2025-11-30T22:19:19+0000 5LZ84spRhc [info] request to updater
2025-11-30T22:19:19+0000 5LZ84spRhc [info] currentStep()
2025-11-30T22:19:19+0000 5LZ84spRhc [info] POST request for step “1”
2025-11-30T22:19:19+0000 5LZ84spRhc [info] startStep(“1”)
2025-11-30T22:19:19+0000 5LZ84spRhc [info] checkForExpectedFilesAndFolders()
2025-11-30T22:19:19+0000 5LZ84spRhc [info] end of checkForExpectedFilesAndFolders()
2025-11-30T22:19:19+0000 5LZ84spRhc [info] endStep(“1”)
2025-11-30T22:19:19+0000 GTgYn8UtjI [info] request to updater
2025-11-30T22:19:19+0000 GTgYn8UtjI [info] currentStep()
2025-11-30T22:19:19+0000 GTgYn8UtjI [info] Step 1 is in state “end”.
2025-11-30T22:19:19+0000 GTgYn8UtjI [info] POST request for step “2”
2025-11-30T22:19:19+0000 GTgYn8UtjI [info] startStep(“2”)
2025-11-30T22:19:19+0000 GTgYn8UtjI [info] checkWritePermissions()
2025-11-30T22:19:19+0000 GTgYn8UtjI [info] end of checkWritePermissions()
2025-11-30T22:19:19+0000 GTgYn8UtjI [info] endStep(“2”)
2025-11-30T22:19:19+0000 jmIfzQdol4 [info] request to updater
2025-11-30T22:19:19+0000 jmIfzQdol4 [info] currentStep()
2025-11-30T22:19:19+0000 jmIfzQdol4 [info] Step 2 is in state “end”.
2025-11-30T22:19:19+0000 jmIfzQdol4 [info] POST request for step “3”
2025-11-30T22:19:19+0000 jmIfzQdol4 [info] startStep(“3”)
2025-11-30T22:19:19+0000 jmIfzQdol4 [info] createBackup()
2025-11-30T22:19:19+0000 jmIfzQdol4 [info] backup folder location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/backups/nextcloud-31.0.4.1-1764541159/
2025-11-30T22:19:56+0000 jmIfzQdol4 [info] end of createBackup()
2025-11-30T22:19:56+0000 jmIfzQdol4 [info] endStep(“3”)
2025-11-30T22:19:56+0000 kF52WTKAOM [info] request to updater
2025-11-30T22:19:56+0000 kF52WTKAOM [info] currentStep()
2025-11-30T22:19:56+0000 kF52WTKAOM [info] Step 3 is in state “end”.
2025-11-30T22:19:56+0000 kF52WTKAOM [info] POST request for step “4”
2025-11-30T22:19:56+0000 kF52WTKAOM [info] startStep(“4”)
2025-11-30T22:19:56+0000 kF52WTKAOM [info] downloadUpdate()
2025-11-30T22:19:56+0000 kF52WTKAOM [info] getUpdateServerResponse()
2025-11-30T22:19:56+0000 kF52WTKAOM [info] updaterServer: https://updates.nextcloud.com/updater_server/
2025-11-30T22:19:56+0000 kF52WTKAOM [info] releaseChannel: stable
2025-11-30T22:19:56+0000 kF52WTKAOM [info] internal version: 31.0.4.1
2025-11-30T22:19:56+0000 kF52WTKAOM [info] updateURL: https://updates.nextcloud.com/updater_server/?version=31x0x4x1xxxstablexx2025-04-17T09%3A09%3A41%2B00%3A00+f3ea37085207b00904ae08faed2acec8c12d0774x8x2x29
2025-11-30T22:19:56+0000 kF52WTKAOM [info] getUpdateServerResponse response: Array
2025-11-30T22:19:56+0000 kF52WTKAOM [info] storage location exists
2025-11-30T22:20:03+0000 kF52WTKAOM [info] end of downloadUpdate()
2025-11-30T22:20:03+0000 kF52WTKAOM [info] endStep(“4”)
2025-11-30T22:20:04+0000 NfMh3ZOUVK [info] request to updater
2025-11-30T22:20:04+0000 NfMh3ZOUVK [info] currentStep()
2025-11-30T22:20:04+0000 NfMh3ZOUVK [info] Step 4 is in state “end”.
2025-11-30T22:20:04+0000 NfMh3ZOUVK [info] POST request for step “5”
2025-11-30T22:20:04+0000 NfMh3ZOUVK [error] POST request failed with other exception
2025-11-30T22:20:04+0000 NfMh3ZOUVK [error] Exception: Exception
2025-11-30T22:26:40+0000 7hgrRPG7QM [info] request to updater
2025-11-30T22:26:40+0000 7hgrRPG7QM [info] currentStep()
2025-11-30T22:26:40+0000 7hgrRPG7QM [info] Step 4 is in state “end”.
2025-11-30T22:26:40+0000 7hgrRPG7QM [info] POST request for step “5”
2025-11-30T22:26:40+0000 7hgrRPG7QM [error] POST request failed with other exception
2025-11-30T22:26:40+0000 7hgrRPG7QM [error] Exception: Exception
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] request to updater
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] currentStep()
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] Step 4 is in state “end”.
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] show HTML page
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] current version: 31.0.4 build time: 2025-04-17T09:09:41+00:00 f3ea37085207b00904ae08faed2acec8c12d0774
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] getUpdateServerResponse()
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] updaterServer: https://updates.nextcloud.com/updater_server/
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] releaseChannel: stable
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] internal version: 31.0.4.1
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] updateURL: https://updates.nextcloud.com/updater_server/?version=31x0x4x1xxxstablexx2025-04-17T09%3A09%3A41%2B00%3A00+f3ea37085207b00904ae08faed2acec8c12d0774x8x2x29
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] getUpdateServerResponse response: Array
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] checkForUpdate() Array
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] getChangelogURL()
2025-11-30T22:30:16+0000 Q1eWLqeBaj [info] end of checkForUpdate() Update to Nextcloud 31.0.11 available. (channel: “stable”)Following file will be downloaded automatically: https://download.nextcloud.com/server/releases/nextcloud-31.0.11.zipOpen changelog :up_right_arrow:
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] request to updater
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] currentStep()
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] Step 4 is in state “end”.
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] POST request for step “5”
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] startStep(“5”)
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] verifyIntegrity()
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] getUpdateServerResponse()
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] updaterServer: https://updates.nextcloud.com/updater_server/
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] releaseChannel: stable
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] internal version: 31.0.4.1
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] updateURL: https://updates.nextcloud.com/updater_server/?version=31x0x4x1xxxstablexx2025-04-17T09%3A09%3A41%2B00%3A00+f3ea37085207b00904ae08faed2acec8c12d0774x8x2x29
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] getUpdateServerResponse response: Array
2025-11-30T22:31:09+0000 MkfS5CNSYW [info] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/
2025-11-30T22:31:10+0000 MkfS5CNSYW [info] end of verifyIntegrity()
2025-11-30T22:31:10+0000 MkfS5CNSYW [info] endStep(“5”)
2025-11-30T22:31:10+0000 ciEpte6eeq [info] request to updater
2025-11-30T22:31:10+0000 ciEpte6eeq [info] currentStep()
2025-11-30T22:31:10+0000 ciEpte6eeq [info] Step 5 is in state “end”.
2025-11-30T22:31:10+0000 ciEpte6eeq [info] POST request for step “6”
2025-11-30T22:31:10+0000 ciEpte6eeq [info] startStep(“6”)
2025-11-30T22:31:10+0000 ciEpte6eeq [info] extractDownload()
2025-11-30T22:31:10+0000 ciEpte6eeq [info] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/
2025-11-30T22:31:10+0000 ciEpte6eeq [info] Libzip version detected: 1.7.3
2025-11-30T22:31:15+0000 ciEpte6eeq [info] end of extractDownload()
2025-11-30T22:31:15+0000 ciEpte6eeq [info] endStep(“6”)
2025-11-30T22:31:15+0000 rDSt3ojAus [info] request to updater
2025-11-30T22:31:15+0000 rDSt3ojAus [info] currentStep()
2025-11-30T22:31:15+0000 rDSt3ojAus [info] Step 6 is in state “end”.
2025-11-30T22:31:15+0000 rDSt3ojAus [info] POST request for step “7”
2025-11-30T22:31:15+0000 rDSt3ojAus [info] startStep(“7”)
2025-11-30T22:31:15+0000 rDSt3ojAus [info] setMaintenanceMode(“true”)
2025-11-30T22:31:15+0000 rDSt3ojAus [info] configFileName /var/www/nextcloud/updater/../config/config.php
2025-11-30T22:31:15+0000 rDSt3ojAus [info] end of setMaintenanceMode()
2025-11-30T22:31:15+0000 rDSt3ojAus [info] endStep(“7”)
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] request to updater
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] currentStep()
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] Step 7 is in state “end”.
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] POST request for step “8”
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] startStep(“8”)
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] replaceEntryPoints()
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] replace index.php
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] replace status.php
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] replace remote.php
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] replace public.php
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] replace ocs/v1.php
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] replace ocs/v2.php
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] end of replaceEntryPoints()
2025-11-30T22:31:15+0000 7Iq6XrNgP0 [info] endStep(“8”)
2025-11-30T22:31:15+0000 7FRqPzHqMO [info] request to updater
2025-11-30T22:31:15+0000 7FRqPzHqMO [info] currentStep()
2025-11-30T22:31:15+0000 7FRqPzHqMO [info] Step 8 is in state “end”.
2025-11-30T22:31:15+0000 7FRqPzHqMO [info] POST request for step “9”
2025-11-30T22:31:15+0000 7FRqPzHqMO [info] startStep(“9”)
2025-11-30T22:31:15+0000 7FRqPzHqMO [info] deleteOldFiles()
2025-11-30T22:31:17+0000 7FRqPzHqMO [info] config sample exists
2025-11-30T22:31:17+0000 7FRqPzHqMO [info] themes README exists
2025-11-30T22:31:18+0000 7FRqPzHqMO [info] end of deleteOldFiles()
2025-11-30T22:31:18+0000 7FRqPzHqMO [info] endStep(“9”)
2025-11-30T22:31:18+0000 5AtQNdWmqK [info] request to updater
2025-11-30T22:31:18+0000 5AtQNdWmqK [info] currentStep()
2025-11-30T22:31:18+0000 5AtQNdWmqK [info] Step 9 is in state “end”.
2025-11-30T22:31:18+0000 5AtQNdWmqK [info] POST request for step “10”
2025-11-30T22:31:18+0000 5AtQNdWmqK [info] startStep(“10”)
2025-11-30T22:31:18+0000 5AtQNdWmqK [info] moveNewVersionInPlace()
2025-11-30T22:31:18+0000 5AtQNdWmqK [info] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/nextcloud/
2025-11-30T22:31:46+0000 5AtQNdWmqK [info] end of moveNewVersionInPlace()
2025-11-30T22:31:46+0000 5AtQNdWmqK [info] endStep(“10”)
2025-11-30T22:31:54+0000 2gFv9fPDib [info] request to updater
2025-11-30T22:31:54+0000 2gFv9fPDib [info] currentStep()
2025-11-30T22:31:54+0000 2gFv9fPDib [info] Step 10 is in state “end”.
2025-11-30T22:31:54+0000 2gFv9fPDib [info] POST request for step “11”
2025-11-30T22:31:54+0000 2gFv9fPDib [info] startStep(“11”)
2025-11-30T22:31:54+0000 2gFv9fPDib [info] setMaintenanceMode(“false”)
2025-11-30T22:31:54+0000 2gFv9fPDib [info] configFileName /var/www/nextcloud/updater/../config/config.php
2025-11-30T22:31:54+0000 2gFv9fPDib [info] end of setMaintenanceMode()
2025-11-30T22:31:54+0000 2gFv9fPDib [info] endStep(“11”)
2025-11-30T22:31:54+0000 CtAPram2Dl [info] request to updater
2025-11-30T22:31:54+0000 CtAPram2Dl [info] currentStep()
2025-11-30T22:31:54+0000 CtAPram2Dl [info] Step 11 is in state “end”.
2025-11-30T22:31:54+0000 CtAPram2Dl [info] POST request for step “12”
2025-11-30T22:31:54+0000 CtAPram2Dl [info] startStep(“12”)
2025-11-30T22:31:54+0000 CtAPram2Dl [info] finalize()
2025-11-30T22:31:54+0000 CtAPram2Dl [info] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/nextcloud/
2025-11-30T22:31:54+0000 CtAPram2Dl [info] call opcache_reset()
2025-11-30T22:31:54+0000 CtAPram2Dl [info] end of finalize()
2025-11-30T22:31:54+0000 CtAPram2Dl [info] endStep(“12”)
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] request to updater
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] currentStep()
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] show HTML page
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] current version: 31.0.11 build time: 2025-11-20T10:02:59+00:00 b883fe276498a48863b61cdaaaca5eb51823504f
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] getUpdateServerResponse()
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] updaterServer: https://updates.nextcloud.com/updater_server/
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] releaseChannel: stable
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] internal version: 31.0.11.2
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] updateURL: https://updates.nextcloud.com/updater_server/?version=31x0x11x2xxxstablexx2025-11-20T10%3A02%3A59%2B00%3A00+b883fe276498a48863b61cdaaaca5eb51823504fx8x2x29
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] getUpdateServerResponse response: Array
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] checkForUpdate() Array
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] getChangelogURL()
2025-11-30T22:38:08+0000 eXOZbRqHGK [info] end of checkForUpdate() Update to Nextcloud 32.0.2 available. (channel: “stable”)Following file will be downloaded automatically: https://github.com/nextcloud-releases/server/releases/download/v32.0.2/nextcloud-32.0.2.zipOpen changelog :up_right_arrow:
2025-11-30T22:38:12+0000 kyhKy24o10 [info] request to updater
2025-11-30T22:38:12+0000 kyhKy24o10 [info] currentStep()
2025-11-30T22:38:12+0000 kyhKy24o10 [info] POST request for step “1”
2025-11-30T22:38:12+0000 kyhKy24o10 [info] startStep(“1”)
2025-11-30T22:38:12+0000 kyhKy24o10 [info] checkForExpectedFilesAndFolders()
2025-11-30T22:38:12+0000 kyhKy24o10 [info] end of checkForExpectedFilesAndFolders()
2025-11-30T22:38:12+0000 kyhKy24o10 [info] endStep(“1”)
2025-11-30T22:38:12+0000 KDvQ6rI1sT [info] request to updater
2025-11-30T22:38:12+0000 KDvQ6rI1sT [info] currentStep()
2025-11-30T22:38:12+0000 KDvQ6rI1sT [info] Step 1 is in state “end”.
2025-11-30T22:38:12+0000 KDvQ6rI1sT [info] POST request for step “2”
2025-11-30T22:38:12+0000 KDvQ6rI1sT [info] startStep(“2”)
2025-11-30T22:38:12+0000 KDvQ6rI1sT [info] checkWritePermissions()
2025-11-30T22:38:12+0000 KDvQ6rI1sT [info] end of checkWritePermissions()
2025-11-30T22:38:12+0000 KDvQ6rI1sT [info] endStep(“2”)
2025-11-30T22:38:12+0000 9CTF8EnZj6 [info] request to updater
2025-11-30T22:38:12+0000 9CTF8EnZj6 [info] currentStep()
2025-11-30T22:38:12+0000 9CTF8EnZj6 [info] Step 2 is in state “end”.
2025-11-30T22:38:12+0000 9CTF8EnZj6 [info] POST request for step “3”
2025-11-30T22:38:12+0000 9CTF8EnZj6 [info] startStep(“3”)
2025-11-30T22:38:12+0000 9CTF8EnZj6 [info] createBackup()
2025-11-30T22:38:12+0000 9CTF8EnZj6 [info] backup folder location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/backups/nextcloud-31.0.11.2-1764542292/
2025-11-30T22:38:42+0000 9CTF8EnZj6 [info] end of createBackup()
2025-11-30T22:38:42+0000 9CTF8EnZj6 [info] endStep(“3”)
2025-11-30T22:38:42+0000 aFd941fsbv [info] request to updater
2025-11-30T22:38:42+0000 aFd941fsbv [info] currentStep()
2025-11-30T22:38:42+0000 aFd941fsbv [info] Step 3 is in state “end”.
2025-11-30T22:38:42+0000 aFd941fsbv [info] POST request for step “4”
2025-11-30T22:38:42+0000 aFd941fsbv [info] startStep(“4”)
2025-11-30T22:38:42+0000 aFd941fsbv [info] downloadUpdate()
2025-11-30T22:38:42+0000 aFd941fsbv [info] getUpdateServerResponse()
2025-11-30T22:38:42+0000 aFd941fsbv [info] updaterServer: https://updates.nextcloud.com/updater_server/
2025-11-30T22:38:42+0000 aFd941fsbv [info] releaseChannel: stable
2025-11-30T22:38:42+0000 aFd941fsbv [info] internal version: 31.0.11.2
2025-11-30T22:38:42+0000 aFd941fsbv [info] updateURL: https://updates.nextcloud.com/updater_server/?version=31x0x11x2xxxstablexx2025-11-20T10%3A02%3A59%2B00%3A00+b883fe276498a48863b61cdaaaca5eb51823504fx8x2x29
2025-11-30T22:38:42+0000 aFd941fsbv [info] getUpdateServerResponse response: Array
2025-11-30T22:38:42+0000 aFd941fsbv [info] will try to download archive from: https://github.com/nextcloud-releases/server/releases/download/v32.0.2/nextcloud-32.0.2.zip, https://download.nextcloud.com/server/releases/nextcloud-32.0.2.zip
2025-11-30T22:38:42+0000 aFd941fsbv [info] storage location already exists
2025-11-30T22:38:42+0000 aFd941fsbv [info] download progress: 2% (4.43MiB of 294.95MiB)
2025-11-30T22:38:42+0000 aFd941fsbv [info] download progress: 4% (10.33MiB of 294.95MiB)
2025-11-30T22:38:43+0000 aFd941fsbv [info] download progress: 6% (16.23MiB of 294.95MiB)
2025-11-30T22:38:43+0000 aFd941fsbv [info] download progress: 8% (22.13MiB of 294.95MiB)
2025-11-30T22:38:43+0000 aFd941fsbv [info] download progress: 10% (28.02MiB of 294.95MiB)
2025-11-30T22:38:44+0000 aFd941fsbv [info] download progress: 20% (57.53MiB of 294.95MiB)
2025-11-30T22:38:45+0000 aFd941fsbv [info] download progress: 30% (87.02MiB of 294.95MiB)
2025-11-30T22:38:46+0000 aFd941fsbv [info] download progress: 40% (116.51MiB of 294.95MiB)
2025-11-30T22:38:46+0000 aFd941fsbv [info] download progress: 50% (146.01MiB of 294.95MiB)
2025-11-30T22:38:47+0000 aFd941fsbv [info] download progress: 60% (175.5MiB of 294.95MiB)
2025-11-30T22:38:48+0000 aFd941fsbv [info] download progress: 70% (205MiB of 294.95MiB)
2025-11-30T22:38:49+0000 aFd941fsbv [info] download progress: 80% (234.49MiB of 294.95MiB)
2025-11-30T22:38:50+0000 aFd941fsbv [info] download progress: 90% (263.99MiB of 294.95MiB)
2025-11-30T22:38:51+0000 aFd941fsbv [info] download progress: 100% (293.49MiB of 294.95MiB)
2025-11-30T22:38:51+0000 aFd941fsbv [info] download stats: size=294.95MiB bytes; total_time=8.92 secs; avg speed=33.07MiB/sec
2025-11-30T22:38:51+0000 aFd941fsbv [info] end of downloadUpdate()
2025-11-30T22:38:51+0000 aFd941fsbv [info] endStep(“4”)
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] request to updater
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] currentStep()
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] Step 4 is in state “end”.
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] POST request for step “5”
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] startStep(“5”)
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] verifyIntegrity()
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] getUpdateServerResponse()
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] updaterServer: https://updates.nextcloud.com/updater_server/
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] releaseChannel: stable
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] internal version: 31.0.11.2
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] updateURL: https://updates.nextcloud.com/updater_server/?version=31x0x11x2xxxstablexx2025-11-20T10%3A02%3A59%2B00%3A00+b883fe276498a48863b61cdaaaca5eb51823504fx8x2x29
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] getUpdateServerResponse response: Array
2025-11-30T22:38:51+0000 qVMOmA5vXQ [info] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/
2025-11-30T22:38:52+0000 qVMOmA5vXQ [info] end of verifyIntegrity()
2025-11-30T22:38:52+0000 qVMOmA5vXQ [info] endStep(“5”)
2025-11-30T22:38:52+0000 TqOgNf5CMm [info] request to updater
2025-11-30T22:38:52+0000 TqOgNf5CMm [info] currentStep()
2025-11-30T22:38:52+0000 TqOgNf5CMm [info] Step 5 is in state “end”.
2025-11-30T22:38:52+0000 TqOgNf5CMm [info] POST request for step “6”
2025-11-30T22:38:52+0000 TqOgNf5CMm [info] startStep(“6”)
2025-11-30T22:38:52+0000 TqOgNf5CMm [info] extractDownload()
2025-11-30T22:38:52+0000 TqOgNf5CMm [info] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/
2025-11-30T22:38:52+0000 TqOgNf5CMm [info] Libzip version detected: 1.7.3
2025-11-30T22:38:57+0000 TqOgNf5CMm [info] end of extractDownload()
2025-11-30T22:38:57+0000 TqOgNf5CMm [info] endStep(“6”)
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] request to updater
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] currentStep()
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] Step 6 is in state “end”.
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] POST request for step “7”
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] startStep(“7”)
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] setMaintenanceMode(“true”)
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] configFileName /var/www/nextcloud/updater/../config/config.php
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] end of setMaintenanceMode()
2025-11-30T22:38:57+0000 Ujo3kiFGbm [info] endStep(“7”)
2025-11-30T22:38:57+0000 lCtcmiw4dg [info] request to updater
2025-11-30T22:38:57+0000 lCtcmiw4dg [info] currentStep()
2025-11-30T22:38:57+0000 lCtcmiw4dg [info] Step 7 is in state “end”.
2025-11-30T22:38:57+0000 lCtcmiw4dg [info] POST request for step “8”
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] startStep(“8”)
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] replaceEntryPoints()
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] replace index.php
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] replace status.php
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] replace remote.php
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] replace public.php
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] replace ocs/v1.php
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] replace ocs/v2.php
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] end of replaceEntryPoints()
2025-11-30T22:38:58+0000 lCtcmiw4dg [info] endStep(“8”)
2025-11-30T22:38:58+0000 EmczX6iXU3 [info] request to updater
2025-11-30T22:38:58+0000 EmczX6iXU3 [info] currentStep()
2025-11-30T22:38:58+0000 EmczX6iXU3 [info] Step 8 is in state “end”.
2025-11-30T22:38:58+0000 EmczX6iXU3 [info] POST request for step “9”
2025-11-30T22:38:58+0000 EmczX6iXU3 [info] startStep(“9”)
2025-11-30T22:38:58+0000 EmczX6iXU3 [info] deleteOldFiles()
2025-11-30T22:38:59+0000 EmczX6iXU3 [info] config sample exists
2025-11-30T22:38:59+0000 EmczX6iXU3 [info] themes README exists
2025-11-30T22:39:00+0000 EmczX6iXU3 [info] end of deleteOldFiles()
2025-11-30T22:39:00+0000 EmczX6iXU3 [info] endStep(“9”)
2025-11-30T22:39:00+0000 l1fRCc23cr [info] request to updater
2025-11-30T22:39:00+0000 l1fRCc23cr [info] currentStep()
2025-11-30T22:39:00+0000 l1fRCc23cr [info] Step 9 is in state “end”.
2025-11-30T22:39:00+0000 l1fRCc23cr [info] POST request for step “10”
2025-11-30T22:39:00+0000 l1fRCc23cr [info] startStep(“10”)
2025-11-30T22:39:00+0000 l1fRCc23cr [info] moveNewVersionInPlace()
2025-11-30T22:39:00+0000 l1fRCc23cr [info] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/nextcloud/
2025-11-30T22:39:32+0000 l1fRCc23cr [info] end of moveNewVersionInPlace()
2025-11-30T22:39:32+0000 l1fRCc23cr [info] endStep(“10”)
2025-11-30T22:39:35+0000 4Id0LjOT09 [info] request to updater
2025-11-30T22:39:35+0000 4Id0LjOT09 [info] currentStep()
2025-11-30T22:39:35+0000 4Id0LjOT09 [info] Step 10 is in state “end”.
2025-11-30T22:39:35+0000 4Id0LjOT09 [info] POST request for step “11”
2025-11-30T22:39:36+0000 4Id0LjOT09 [info] startStep(“11”)
2025-11-30T22:39:36+0000 4Id0LjOT09 [info] setMaintenanceMode(“false”)
2025-11-30T22:39:36+0000 4Id0LjOT09 [info] configFileName /var/www/nextcloud/updater/../config/config.php
2025-11-30T22:39:36+0000 4Id0LjOT09 [info] end of setMaintenanceMode()
2025-11-30T22:39:36+0000 4Id0LjOT09 [info] endStep(“11”)
2025-11-30T22:39:36+0000 roz6mrIdyy [info] request to updater
2025-11-30T22:39:36+0000 roz6mrIdyy [info] currentStep()
2025-11-30T22:39:36+0000 roz6mrIdyy [info] Step 11 is in state “end”.
2025-11-30T22:39:36+0000 roz6mrIdyy [info] POST request for step “12”
2025-11-30T22:39:36+0000 roz6mrIdyy [info] startStep(“12”)
2025-11-30T22:39:36+0000 roz6mrIdyy [info] finalize()
2025-11-30T22:39:36+0000 roz6mrIdyy [info] storage location: /mnt/dietpi_userdata/nextcloud_data/updater-ocxyuymwbgg0/downloads/nextcloud/
2025-11-30T22:39:36+0000 roz6mrIdyy [info] call opcache_reset()
2025-11-30T22:39:36+0000 roz6mrIdyy [info] end of finalize()
2025-11-30T22:39:36+0000 roz6mrIdyy [info] endStep(“12”)
I can´t find any hint to a automatically Teamsfolder update. So I think the manually one, I made was the only one this day.
Ah okay. I checked back and while the visual app name changed from Group Folders to Team Folders, the app ID and hence app directory remained the same. The same happened to Circels renamed to Teams and Spreed renamed to Talk, but this has no effect on the update. So no idea what went wrong initially.
Thank you very much for your efforts in trying to help me. I think the best thing to do will be to set up a new Nextcloud and fill it with my backup, which I fortunately have stored locally.
With all Your hints I´ve learned al lot on Linux and Nextcloud.
Thanks again.
Kind regards,
Jochem
Ah sorry, I thought your manual app update solved it.
I recognized an older issue at the app’s repo wa reopened and a new version was released. Maybe that fixed the issue.
