Hey
I’ve been running DietPi on my Raspberry Pi and had a setup with Docker Compose which was functioning perfectly. Using my router’s port forwarding, I was able to access my web applications securely over HTTPS from any browser. Here’s my initial setup:
DietPi v8.21.1 : 1 APT updates available
- Device model : RPi 4 Model B (aarch64)
- CPU temp : 31 °C / 87 °F : Cool runnings
- LAN IP : 192.168.1.80 (eth0)
- MOTD : Open Beta v8.22 | Please help testing our upcoming release:
https://github.com/MichaIng/DietPi/issues/6625
However, I recently added a 4G LTE HAT to my Raspberry Pi. Since then, I noticed the LAN IP has changed and seems to be using wwan0 :
- LAN IP : 10.29.204.36 (wwan0)
Since adding the HAT, I’ve been unable to access my web applications. I checked the ports 80, 443, 8812, and 9009, and all appear to be closed.
Has anyone experienced similar issues with the integration of a 4G LTE HAT on DietPi? Any pointers or solutions to get the port forwarding working with this setup would be greatly appreciated.
Thanks in advance!
dietpi@DietPi:~$ sudo ifconfig
br-5c971b325129: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.18.0.1 netmask 255.255.0.0 broadcast 172.18.255.255
inet6 fe80::42:56ff:fe55:33ff prefixlen 64 scopeid 0x20<link>
ether 02:42:56:55:33:ff txqueuelen 0 (Ethernet)
RX packets 4563 bytes 1915009 (1.8 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 5074 bytes 2741537 (2.6 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:c3:65:cb:86 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.80 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::da3a:ddff:fe48:44e4 prefixlen 64 scopeid 0x20<link>
inet6 2a01:e0a:173:5530:da3a:ddff:fe48:44e4 prefixlen 64 scopeid 0x0<global>
ether d8:3a:dd:48:44:e4 txqueuelen 1000 (Ethernet)
RX packets 9586 bytes 1066652 (1.0 MiB)
TX packets 5071 bytes 2066153 (1.9 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 6 bytes 1520 (1.4 KiB)
TX packets 6 bytes 1520 (1.4 KiB)
veth3480455: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::30dd:1ff:fe2a:6cf3 prefixlen 64 scopeid 0x20<link>
ether 32:dd:01:2a:6c:f3 txqueuelen 0 (Ethernet)
TX packets 25 bytes 1842 (1.7 KiB)
veth9c2a915: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::7062:f6ff:fe3a:2650 prefixlen 64 scopeid 0x20<link>
ether 72:62:f6:3a:26:50 txqueuelen 0 (Ethernet)
RX packets 827 bytes 59961 (58.5 KiB)
TX packets 1370 bytes 1548547 (1.4 MiB)
vethb036cca: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::415:69ff:fe35:c499 prefixlen 64 scopeid 0x20<link>
ether 06:15:69:35:c4:99 txqueuelen 0 (Ethernet)
RX packets 3379 bytes 1869480 (1.7 MiB)
TX packets 3446 bytes 1167854 (1.1 MiB)
vethd887ab3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::e8e2:3eff:fecf:5d04 prefixlen 64 scopeid 0x20<link>
ether ea:e2:3e:cf:5d:04 txqueuelen 0 (Ethernet)
RX packets 4791 bytes 2131719 (2.0 MiB)
TX packets 4741 bytes 2110643 (2.0 MiB)
wwan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 10.29.204.36 netmask 255.255.255.248 destination 10.29.204.36
inet6 fe80::4181:f4a8:b4f1:fd0e prefixlen 64 scopeid 0x20<link>
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
RX packets 2444 bytes 2172770 (2.0 MiB)
TX packets 2149 bytes 320679 (313.1 KiB)
dietpi@DietPi:~$ ip r
default via 10.29.204.37 dev wwan0
10.29.204.32/29 dev wwan0 proto kernel scope link src 10.29.204.36
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.18.0.0/16 dev br-5c971b325129 proto kernel scope link src 172.18.0.1
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.80
dietpi@DietPi:~$ ping -I eth0 www.google.com -c 3
PING www.google.com(par10s41-in-x04.1e100.net (2a00:1450:4007:80d::2004)) from 2a01:e0a:173:5530:da3a:ddff:fe48:44e4 eth0: 56 data bytes
64 bytes from par10s21-in-x04.1e100.net (2a00:1450:4007:80d::2004): icmp_seq=1 ttl=117 time=17.3 ms
64 bytes from par10s21-in-x04.1e100.net (2a00:1450:4007:80d::2004): icmp_seq=2 ttl=117 time=17.7 ms
64 bytes from par10s21-in-x04.1e100.net (2a00:1450:4007:80d::2004): icmp_seq=3 ttl=117 time=17.9 ms
dietpi@DietPi:~$ ping -I wwan0 www.google.com -c 3
PING (142.250.201.164) from 10.29.204.36 wwan0: 56(84) bytes of data.
64 bytes from par21s23-in-f4.1e100.net (142.250.201.164): icmp_seq=1 ttl=116 time=140 ms
64 bytes from par21s23-in-f4.1e100.net (142.250.201.164): icmp_seq=2 ttl=116 time=58.6 ms
64 bytes from par21s23-in-f4.1e100.net (142.250.201.164): icmp_seq=3 ttl=116 time=57.3 ms
