my DietPi v6.34.3 (beta) : 21:19 - Mi 03.02.2021 - Device model : RPi 3 Model B (armv7l) shows me that the plexmediaserver service is started,
root@DietPi:~# systemctl -l status plexmediaserver
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; disabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/plexmediaserver.service.d
└─dietpi-group.conf
Active: active (running) since Wed 2021-02-03 21:11:55 CET; 19min ago
Process: 1357 ExecStartPre=/bin/sh -c /usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -p “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Main PID: 1362 (Plex Media Serv)
Tasks: 55 (limit: 2092)
CGroup: /system.slice/plexmediaserver.service
├─1362 /usr/lib/plexmediaserver/Plex Media Server
├─1519 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-a91458577/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.21.2.3943-a9145
8577 /usr/lib/plexmediaserver/Resources/Plug-ins-a91458577/System.bundle
├─1813 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.21.2.3943-a91458577 32600 /waitmutex
└─1855 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-a91458577/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.21.2.3943-
a91458577 /usr/lib/plexmediaserver/Resources/Plug-ins-a91458577/PlexMovie.bundle
Feb 03 21:11:55 DietPi systemd[1]: Starting Plex Media Server…
Feb 03 21:11:55 DietPi systemd[1]: Started Plex Media Server.
yet I can’t access the configuration page:
https://192.168.115.30:32400/web
The website is unreachable192.168.115.30 has closed the connection unexpectedly.
I have already reinstalled Plex twice with the same negative result.
What can be done?
Many kind regards.
Edit:
I flush the cache from chrome browser, this solved the problem. With edge browser I have no problems with plex configuration.
