Please help; Ampache not functioning
Hi all,
Sorry if this is a silly question. I am using Dietpi on a few Raspberry Pi’s and on one odroid XU4.
I am in the process of evaluating several different music streaming servers. I grew fond of Ampache 3.8.2 through the use of dietpi-software performing the installation. The installation instructions on Ampache’s github page require some doing but Dietpi makes it easy. The Ubuntu repository will only install an earlier alpha version of Ampache. I know that it was working when Dietpi was in the version numbers 127+ to the 130’s but now Ampache is not working for me so I am hoping that you guys can help.
I only just recently tried to install Dietpi on a newly formatted SSD chip with only Ampache chosen from the dietpi-software list, hoping that when Ampache is loaded the dependencies would configure themselves for Ampache and Ampache only. No luck.
I suspect that the issue has to do with the way that mysql is configured because when a browser loads http://localhost/ampache/test.php It displays a page that shows that the Ampache installation has passed all tests except for three. One of them is a warning that has this explanation:
“This tests whether Ampache can manage large files (> 2GB). This is not strictly necessary, but may result in a better experience. This generally requires 64-bit operating system.”
I’m not too worried about that one.
The other two are errors having to do with Ampache’s Mysql database. Those explanations are:
“Database connection: This attempts to connect to your database using the values read from your configuration file.”
and
“Database tables: This checks a few key tables to make sure that you have successfully inserted the Ampache database and that the user has access to the database”
I am hoping that you can reproduce these results. Failing that, is it possible to load an earlier version of Dietpi and adjust the script to bypass the update process to test whether the issue is in there someplace? That may not be the best way to deal with this but I don’t have a lot of experience with Mysql.
Another possibility is that, according to Ampache’s github page, Ampache uses Composer for dependency management. As Composer is being installed by dietpi-software the console displays warning messages about not using root to install Composer and also about how something called “guzzler” has been deprecated.
Thanks in advance.
MZ
Hi MZ,
Is this installation on XU4 or RPi? I’ll run some tests here.
This one is pretty much a slam dunk. Either MySQL is failing to run, or, MySQL creds are incorrect. This shouldnt occur unless MySQL has been modified by end user, or, something is broken.
Check status of MySQL with:
systemctl status mysql -l
Ah yes, these are known warnings. However, these warnings are out of our control. DietPi executes the installation script for composer, provided by Ampache:
So unfortunately, we cant make any changes to this at our end. Ampache would need to run tests and modify their code/required packages accordingly.
The root warning is unnecessary in my eyes, unless composer and its modules that get installed, cannot be trusted. In which case, noone should be using it.
I ran a test install on C2, that went fine. But let me know which device you got the errors on, i’ll try to replicate here.
Thanks for responding so quickly.
This has been happening on the odroid XU4 and also on Raspberry pi’s Models 2B and 3B. The most recent attempt that I mentioned was on a Raspberry pi 2 Model B.
I should emphasize that this has been happening only on recent attempts at installation although I couldn’t say when it started happening. Older installations of Ampache still work as they always have.
Thanks for clearing up the business concerning the warnings during the installation of Composer. That’s one possibiity that I can put to rest.
MZ
Hi MZ,
Thanks for the info.
Ran a test here on fresh DietPi install, RPi 3 (same arch), Ampache installs and runs fine.
Could you please send us a bug report? I’d like to check your current system configuration, see if we can find anything that may be the cause. Please follow the guide below:
https://dietpi.com/forum/t/send-dietpi-a-bug-report/421/1
I tried installing Ampache…blank screen when I try to log in
ran the /test.php mentioned above
See this
all the rest of the blocks are green
Nextcloud works fine…but it’s on a Apache2 and Mariadb…
If Ampache isn’t a viable option…is there another lightweight streaming server like Ampache I can use?
I fired off a bug report…my build isn’t a stock build though…so I doubt support is available
reference code: e8583508-1ff3-4bba-af0a-431c5ea76be5
POW!!!
Got it working…
Had to edit /var/www/ampache/config/ampache.cfg.php
Had to change the database password from “dietpi” to my root users password…
Did a dietpi-services restart…and kapow!!!
Building a database of over 60+ gigs of tunes…
Wow, I read and read, your explanation is the one after HOURS that fixed it! Thank you!
Didn’t like Ampache much unfortunately.
I’m really happy with my Subsonic server :slight_smile:
echable WarHawk
Ayayay many thanks for reporting this. Indeed a stupid bug of us. We install a pre-created config file but do not adjust the password inside accordingly to the chosen global software password :roll_eyes:. Will fix it!
PR up: https://github.com/MichaIng/DietPi/pull/2903
Done!
