Pihole weirdness?
This is one option. Should be the easiest way
conditional forwarding just gets enabled when you put in the config right? there is no checkbox to enable it right? thank you for the help. ill post back when i go to do everything. :slight_smile:
Yes, when you add the line and it starts with true, otherwise it’s still disabled.
if i input the wrong ip or whatever it is overwritten when i input it again? havent done it yet just making sure. :slight_smile:
There is no need to do this part yet. First step would be to adjust DHCP server settings to get some details on the client doing these request you are looking for.
the guy at bit defender said i don’t need to swap dhcp to pihole and that it would work through dns? is that wrong? just know im in the dark and im most likely just going to swap dhcp if this is to hard for me to do. :slight_smile:
edit: also what would be the procedure?
  1. turn on dhcp on pi-hole
  2. turn off dhcp for router
  3. conditional forwarding
You have 2 options to get clients visible in PiHole
  1. adjust the DHCP server on your router to distribute PiHole as DNS server directly
  2. disabled DHCP server in your router and enable DHCP in PiHole
We are now running around this setting half of the day now. It takes 1 minute to change and will bring you closer to your question who is doing the unknown DNS requested.
The only dhcp settings i see are to change its ip range and lease time or disable it. i dont get what you mean by have the router distribute pihole as dns directly. i already set pihole as the top dns server.
Simply disable DHCP on the router and have it enabled in PiHole. Over time (depending on current lease time) your clients will use pihole as their upstream DNS server instead of your router.
It is set as upstream DNS for the router but not for your clients.
i don’t see what setting to change. the only dns thing on here i see is to change the dns ip. nothing about downstream or upstream or anything about clients that has to do with dns or even dhcp other than ip lease time or a off button. is this something that is used with minipc routers? i wont be getting another netgear router…
Disable DHCP on your router and have it enabled in PiHole
um so doing it that way wont cut off the connection before i can enable it on pi-hole? (dont know anything about routers) should I enable dhcp on pi-hole then disable it on the router?
Disabling dhcp will not impact any client running. Simply do it the order you like, it’s seconds between Disabling and enabling.
cool do i need to copy the ip ranges or does that auto fill in?
You would need to adjust settings in PiHole on your needs
k disabled dhcp on router and enabled on the pi.. saved and applied then did ftl restart. um i dont see it giving any leases. does that take time?
EDIT: oh it seems one device is already showing correctly. :slight_smile:
Yes
For mobile devices you can force this be turning wifi off/on. Others you might need to reboot or wait until they are going to refresh IP address assignments
So far its working and I think the queries are coming from my worthless netgear router with built in “armor” that says its disabled. first I’ll restart it a few times and see if a device pops up in pi-hole then if the routers ip is still there I’m gana factory reset my router.
Don’t forget to disable DHCP again afterwards.
pls don’t mix topics and open an own one for this
