I can’t click on it successfully, whether with Firefox or Chromium?
- DietPi version |
cat /boot/dietpi/.version - G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=16
G_DIETPI_VERSION_RC=3
G_LIVE_PATCH_STATUS[2]=‘applied’ - Distro version |
echo $G_DISTRO_NAME $G_RASPBIAN - trixie 1
- Kernel version |
uname --all - Linux DietPi 6.12.34+rpt-rpi-v6 #1 Raspbian 1:6.12.34-1+rpt1 (2025-06-26) armv6l GNU/Linux
- Architecture |
dpkg --print-architecture - armhf
- SBC model |
echo $G_HW_MODEL_NAMEor (EG: RPi3) - RPi B (armv6l)
- Power supply used | (EG: 5V 1A RAVpower)
- Powerbank
- SD card used | (EG: SanDisk ultra)
- Kexin 32 GB micro SD HC I
- WLan
- Yes
Power off and boot again. Or reboot the device. Without LAN cable
- The network should establish a Wi-Fi connection.
- The Wi-Fi connection is only established if LAN is available at the same time. It does not matter whether LAN is enabled or disabled in dietpi-config. If only the Wi-Fi USB stick is plugged in, the network will not start. There is no activity on the network LEDs; they do not flash.
- The old PI1 B again.
- root@DietPi:~# dmesg|grep -i wlan
[ 4.611571] usb 1-1.2: Product: 802.11 n WLAN
[ 33.775506] wlan0: authenticate with 04:a2:22:ac:db:56 (local address=a0:47:d7:52:b6:67)
[ 33.775569] wlan0: send auth to 04:a2:22:ac:db:56 (try 1/3)
[ 33.778951] wlan0: authenticated
[ 33.789146] wlan0: associate with 04:a2:22:ac:db:56 (try 1/3)
[ 33.794450] wlan0: RX AssocResp from 04:a2:22:ac:db:56 (capab=0x1431 status=0 aid=3)
[ 33.846313] wlan0: associated
[ 33.847336] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 04:a2:22:ac:db:56
