I’m running the most current DietPi version with all apt upgrades installed on Raspberry Pi Zero W.
I have a USB soundcard which run on Raspbian after these instructions: https://raspberrypi.stackexchange.com/questions/80072/how-can-i-use-an-external-usb-sound-card-and-set-it-as-default.
I have used dietpi-config to set the card as the default audio device (the utility correctly sees the card whenever it’s inserted and shows it as a plugged in device on the bottom at hw:1,0 as Device USB Audio)
However, afterwards the soundcard doesn’t produce any sound.
aplay -l && arecord -l results in
aplay: device_list:274: no soundcards found...
arecord: device_list:274: no soundcards found...
cat /proc/asound/cards shows
1 [Device ]: USB-Audio - USB PnP Sound Device
C-Media Electronics Inc. USB PnP Sound Device at usb-20980000.usb-1.2, full spe
cat /proc/asound/modules shows 1 snd_usb_audio
amixer -c 1 shows Invalid card number.
/usr/share/alsa/alsa.conf has defaults.ctl.card 1 and defaults.pcm.card 1
during the process of using dietpi-config to change the audio device an error shows up:
[ OK ] DietPi-Set_hardware | rm /var/lib/alsa/asound.state
alsa-lib parser.c:2179:(load_toplevel_config) Unable to find the top-level configuration file '/usr/share/alsa/ucm2/ucm.conf'.
alsa-lib main.c:1014:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -2
Found hardware: "USB-Audio" "USB Mixer" "USB8086:0808" "" ""
Hardware is initialized using a generic method
I have tried rebooting, cold booting, going through dietpi-config multiple times, but nothing seems to work.
