Hi at all,
I have the Adapter shown on the Photo and it wont Work. Its LEDs light up and keep blinking. I have a similar adapter (same White Case) with another Chip (I guess) that works just fine.
So do I have to buy another one?
Does this adapter is working with plain RPi OS?
Would have to try. Do not have an SD card with that. I only use dietpi.
Would be interesting to see how it behaves. Do you have a spare SD card available?
Regarding to some posts in the official RPi forums it’s possible that they indeed use different network chips in the same adapter.
Some users wrote, he got it working when the adapter is connected and he rebooted.
And also this guy got it working: USB devices for Raspberry Pi – Arduino, Raspberry Pi and ESP8266 Small Computers!
Is the adapter at least recognized as something when you connect it to your SBC?
lsusb
Gonna need a special driver, might be pre-compiled in module form
Might be a VERY old and obsolete chipset that is no longer supported
Compiling Ethernet driver for RD9700 USB to ETHERNET ( Enter : E-100u ) in Ubuntu 14.04 ~ Missing Knowledge (ssumansaurabh.blogspot.com)
The GNU/Linux “usbnet” Driver (linux-usb.org)
RD9700 USB Ethernet adapter driver disc : Free Download, Borrow, and Streaming : Internet Archive
Will try another Image. What do you recommend? Will try it with my fresh sd card.
Is there a simple way to implement the driver and flash the diet pi image before using it for the first?
That shows it was working in 2015. Why would someone remove a driver?
cleaning up old unsupported driver?
you can try to original RPi OS image.
Will flash this and report back:
Raspberry Pi OS with desktop and recommended software
Release date: September 22nd 2022
System: 32-bit
Kernel version: 5.15
Debian version: 11 (bullseye)
I guess the light version should be enough
Raspberry Pi OS Lite
System: 32-bit
Does it have SSH built in as dietpi does?
you need to place a file on the boot folder before first boot happen Raspberry Pi Documentation - Remote access
For headless setup, SSH can be enabled by placing a file named
ssh, without any extension, onto the boot partition of the SD Card. When the Raspberry Pi boots, it looks for thesshfile. If it is found, SSH is enabled and the file is deleted. The content of the file does not matter; it could contain text, or nothing at all.
Did it. Unfortunately IP scanner does not find it. Seems to manually need a driver install which is quite complicated for a headless device with only 1 USB Port.
In this case the adapter is not working together with your SBC and you would need to check for a different one.
I Had a similar problem years ago and simply connecting via usb hub in front of the (otherwise not working) LAN adapter fixed it. Is that possible Here?
just give it a try. ![]()
