Pi-hole PADD problem under DietPi v8.12.1?
I’ll change the default console log level to errors only with next release. Please do so with:
G_CONFIG_INJECT 'kernel.printk = ' 'kernel.printk = 4 4 1 7' /etc/sysctl.d/dietpi.conf
sysctl -w 'kernel.printk = 4 4 1 7'
It works, very nice.
Follow output shouldn’t be a problem though?
root@pihole:~#sysctl -w ‘kernel.printk = 4 4 1 7’
sysctl: cannot stat /proc/sys/kernel/printk : No such file or directory
Merged with: v8.13 · MichaIng/DietPi@5c9b771 · GitHub
Hmm, does this work from console without error?
sysctl -w kernel.printk='4 4 1 7'
I logged in using ssh, typed the first line of your commands, then the second line and it gave this output.
Then I did a reboot and the display is now completely fine again.
By the way, it also works on the NanoPi with TFT.
Ah the syntax was wrong for console, where no space must be present before and after equal sign. However, the reboot had just the same effect, of course:
root@VM-Bookworm:~# sysctl -w 'kernel.printk = 4 4 1 7'
root@VM-Bookworm:~# sysctl -w 'kernel.printk=4 4 1 7'
Thanks for the great support!
A little donate via Paypal is on the way!
