I have the PecanPi® DAC running with ropieeeXL but airplay function seems very unstable compared to my usbridge signature running DietPi. However from what I can read, there are no “drivers” installed for the PecanPi If I install DietPi? I use it as roon bridge and endpoint, and then airplay function for my daughter that refuse to go away from her music on Apple. That’s why I need airplay. Are there a workaround for installing PecanPi on DietPi?
You would use the RPI-DAC driver. It is fully compatible with PecanPi DAC.
