Orangepi Zero 2w compact sound box and more with PCM5102A via i2s
If you would go deeper inside the source code you must see in the source file and search around i2s0, sound ,snd, sunxi, codec
have a look at the source code for H6
Good luck :wink:
Hi again
Here the official kernel in sunxi github’s folder
now set armbian and got -
no soundcards found…
used your old script -
/dts-v1/;
/plugin/;
compatible = “allwinner,sun50i-h616”;
fragment@0 {
target = <&pio>;
overlay {
ahub_daudio0_pins_a: ahub_daudio0@0 {
pins = “PI0”, “PI1”, “PI2”;
function = “i2s0”;
drive-strength = <0x14>;
bias-disable;
ahub_daudio0_pins_b: ahub_daudio0@1 {
pins = “PI3”;
function = “i2s0_dout0”;
bias-disable;
ahub_daudio0_pins_c: ahub_daudio0@2 {
pins = “PI4”;
function = “i2s0_din0”;
bias-disable;
ahub_daudio0_pins_d: ahub_daudio0_sleep {
pins = “PI0”, “PI1”, “PI2”, “PI3”, “PI4”;
function = “gpio_in”;
bias-disable;
fragment@1 {
target-path = “/soc”;
overlay {
ahub0_plat: ahub0_plat {
#sound-dai-cells = <0>;
compatible = “allwinner,sunxi-snd-plat-ahub”;
apb_num = <0>; /* for dma port 3 */
dmas = <&dma 3>, <&dma 3>;
dma-names = “tx”, “rx”;
playback_cma = <128>;
capture_cma = <128>;
tx_fifo_size = <128>;
rx_fifo_size = <128>;
	pinctrl-names = "default", "sleep";
            pinctrl_used;
	pinctrl-0 = <&ahub_daudio0_pins_a>, <&ahub_daudio0_pins_b>, <&ahub_daudio0_pins_c>;
	pinctrl-1 = <&ahub_daudio0_pins_d>;
            status = "okay";
        ahub0_mach: ahub0_mach {
            compatible = "allwinner,sunxi-snd-mach";
	soundcard-mach,name = "ahubi2s0";
	soundcard-mach,format = "i2s";
	status = "okay";
            soundcard-mach,cpu {
	    sound-dai = <&ahub0_plat>;
	soundcard-mach,codec {
Hello rx9cim
My script is here for the whole version with the command to create it and applied
in fact i don’t know if it works with armbian
