Orange Pi 5+ How to Configure PWM Fan Kernel 6.18 (DietPi v10.5.2)?
I found problem similar with this post post with this solution is only working with kernel 5 refer to this pwm-fan source version 5.10 that based on this orange pi 5 plus wiki the pwm-fan structure like this
   fan: pwm-fan {
      compatible = "pwm-fan";
      #cooling-cells = <2>;
      pwms = <&pwm3 0 50000 0>;
      cooling-levels = <0 50 100 150 200 255>;
      rockchip,temp-trips = <
         50000 1
         55000 2
         60000 3
         65000 4
         70000 5
      status = "okay";
But nowdays the kernel is upgraded to version 6, and the pwm-fan structure in dtb files has been changed, the latest found in the source tree is 6.1 and the structure become like this:
   `pwm-fan { `
               cooling-levels = <0x00 0x46 0x4b 0x50 0x64>;
               fan-supply = <0x30>;
               #cooling-cells = <0x02>;
               pwms = <0x13d 0x00 0xc350 0x00>;
               phandle = <0xe9>;
I am very newbie, would you like to tell me how to implement temp-trips in the new version kernel?
Thanks
Warm Regards
In the meantime, we use mainline Linux 6.18 by default:
‐ https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5.dtsi#n76
In case, here is how to migrate from vendor Linux 6.1 to mainline Linux 6.18: Rock 5B switch to mainline kernel - #2 by MichaIng
Adjust the U-Boot package name accordingly.
