I am using an odroid XU4 with Logithech Media Server / Squeezelite feeding an ifi Zen Usb dac which is capable of playing hi resolution audio files(pcm 384Khz and DSD)
Every time on initial boot the system recognizes my dac with a limited resolution of 96 Khz.
If i unplug and replug my usb dac then it recognizes it correctly as pcm 384Khz & DSD capable dac.
Any ideas on how to correct this issue are welcome.
Nov 04 11:05:58 DietPi kernel: usb 2-1: Warning! Unlikely big volume range (=32512), cval->res is probably wrong.
Nov 04 11:05:58 DietPi kernel: usb 2-1: [10] FU [iFi (by AMR) USB Audio Playback Volume] ch = 1, val = -32512/0/1
I am afraid it is not a cable issue, i’ ve tried many cables and usb ports with the same result.
If i unplug and replug the cable, dac is recognized correctly.
Also note the dac is recognized correctly if i use Rpi4 instead of Odroid, with Dietpi and the same cable.
