Odroid XU4 flash related boot issue
  • DietPi version | 9.13
  • Distro version | N/A
  • Kernel version | N/A
  • Architecture | Armv7, Armv8
  • SBC model | Odroid XU4 & Odroid N2
  • Power supply used | Official Hardkernel power supply
  • SD card used | Hardkernel official eMMC module
Setup
I have 3 Odroid boards, two are XU4 and the other one is N2. I also also have 3 128G eMMC module (Let’s say eMMC-1, eMMC-2 and eMMC-3). Here is the situation
  1. eMMC-1, eMMC-2 and eMMC-3 can all be recognized by Windows and can be flashed by balenaEtcher or Rufus
  2. After flashing DietPi_OdroidN2-ARMv8-Bookworm.img.xz to eMMC-1, eMMC-2 and eMMC-3, my Odroid N2 boards can boot with all three eMMCs → So I think all eMMCs are functional
  3. Then I leave eMMC-1 for Odroid N2. And flashed DietPi_OdroidXU4-ARMv7-Bookworm.img.xz into eMMC-2 and eMMC-3.
    • eMMC-2 can boot both Odroid XU4
    • Neither Odroid XU4 can be booted by eMMC-3 → no blue light
I’ve tried to flash eMMC-3 for multiple times with balenaEtcher or Rufus, but the behavior is very consistent. Comparing to eMMC-2, I did once deleted its partitions using Windows Disk Management. My questions:
  1. Did I somehow damage the boot partition and it can never be recovered? Any help on how to recover/flash is appreciated.
  2. I tried to use command dd to replicate all 3 partitions (mmcblk0, mmcblk0boot0, mmcblk0boot) of eMMC-2 to eMMC-3, but did not work either (first time doing that might have wrong operations)
Thank you again for this amazing piece of operating system!
So all 3 eMMC modules are identical?
Yes, bought in the same batch. I think I somehow messed up with the partitions but I’m not sure how
TL;DR
I did corrupted the hidden bootloader partition on eMMC modules by doing manual volume deletion on Windows.
The solution is here, basically recover eMMC bootloader: https://wiki.odroid.com/odroid_go_ultra/getting_started/recovery_emmc
