I set up an odroid XU4 with dietpi. When I install emby, it runs stable for a few minutes, but then after a reboot it doesn’t work anymore, or emby just doesn’t start. I also have these problems with Plex. But also if I install dietpi alone and do not add it I have problems. I get the following message when booting dietpi:
MOTD : Check your kernel error logs from time to time: dmesg -l err,crit,alert,emerg
when i do, iget:
root@DietPi:~# dmesg -l err,crit,alert,emerg
[ 1.760820] exynos-hdmi 14530000.hdmi: Failed to get supply 'vdd': -517
[ 1.843575] devfreq devfreq0: Couldn't update frequency transition information.
[ 3.357156] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
[ 3.793737] OF: graph: no port node found in /soc/hdmi@14530000
[ 7.077973] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
[ 7.096170] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
Sorry for my bad English, but I hope you can help me
many thanks for your report. I guess there is a misunderstanding or mix-up of thinks. The MOTD did not indicate that there are issues on your device. It’s more the message of the day and an information about useful thinks / commands on your system. It’s just a simple banner entry that will change time by time.
Saying this, there is no relation to your issues with Plex and Emby. Would be good if you can install both and we could have a look, why services are not starting after a reboot.
Thank you very much for this information, I got a little confused. I have now installed emby and it ran for several hours without any problems. Then I wanted to start something to watch, but no stream was found. So I rebooted. Emby was then only a few minutes started and was then no longer active as service. After another restart emby is running, but it cannot be played. With “htop” embyserver is active.
I have a Raspberry also with emby, there the playback works, so it is not the file.
The settings are so far identical, or I have not changed much.
Where could I find helpful logs?
many greetings
Addendum: Only when I call emby from the browser it seems to crash, but not every time.
I made a video, it can be reproduced. However, I have activated the “debug logging”. Emby runs until I try to access it with the browser. https://youtu.be/pD8eqXRk4f0
it’s probably emby and has nothing to do with dietpi. But i’m not really getting anywhere with emby either. The logs say that there was an error, but I don’t understand how I can fix it. I once attached the log file. Maybe someone can help me.
2020-06-11 10:31:06.176 Info App: Core startup complete
2020-06-11 10:31:06.176 Info App: Post-init migrations complete
2020-06-11 10:31:06.176 Info App: Starting entry point Emby.Webhooks.WebhooksEntryPoint
2020-06-11 10:31:06.181 Info App: Entry point completed: Emby.Webhooks.WebhooksEntryPoint. Duration: 0.0049085 seconds
2020-06-11 10:31:06.181 Info App: Starting entry point NfoMetadata.EntryPoint
2020-06-11 10:31:06.181 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.0004079 seconds
2020-06-11 10:31:06.181 Info App: Starting entry point Emby.Security.PluginSecurityManager
2020-06-11 10:31:06.181 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.0001241 seconds
2020-06-11 10:31:06.181 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint
2020-06-11 10:31:06.182 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0003193 seconds
2020-06-11 10:31:06.182 Info App: Starting entry point AutoBoxSets.ServerEntryPoint
2020-06-11 10:31:06.213 Info App: Entry point completed: AutoBoxSets.ServerEntryPoint. Duration: 0.0309939 seconds
2020-06-11 10:31:06.213 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint
2020-06-11 10:31:06.213 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 0.0002192 seconds
2020-06-11 10:31:06.213 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint
2020-06-11 10:31:06.218 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.0045844 seconds
2020-06-11 10:31:06.218 Info App: Starting entry point Emby.Server.Implementations.Playlists.PlaylistsEntryPoint
2020-06-11 10:31:06.221 Info App: Entry point completed: Emby.Server.Implementations.Playlists.PlaylistsEntryPoint. Duration: 0.0025421 seconds
2020-06-11 10:31:06.221 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint
2020-06-11 10:31:06.222 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0005507 seconds
2020-06-11 10:31:06.222 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint
2020-06-11 10:31:06.223 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0008923 seconds
2020-06-11 10:31:06.223 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup
2020-06-11 10:31:06.735 Info HttpClient: GET > https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog
2020-06-11 10:31:07.332 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 1.1093392 seconds
2020-06-11 10:31:07.332 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint
2020-06-11 10:31:07.333 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0009135 seconds
2020-06-11 10:31:07.333 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake
2020-06-11 10:31:07.334 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0005224 seconds
2020-06-11 10:31:07.334 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier
2020-06-11 10:31:07.337 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0029589 seconds
2020-06-11 10:31:07.337 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier
2020-06-11 10:31:07.341 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0037438 seconds
2020-06-11 10:31:07.341 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard
2020-06-11 10:31:07.342 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0013577 seconds
2020-06-11 10:31:07.342 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents
2020-06-11 10:31:07.343 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0005764 seconds
2020-06-11 10:31:07.343 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier
2020-06-11 10:31:07.343 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0002977 seconds
2020-06-11 10:31:07.343 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint
2020-06-11 10:31:07.351 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0071579 seconds
2020-06-11 10:31:07.351 Info App: Starting entry point Emby.LiveTV.EntryPoint
2020-06-11 10:31:07.356 Info LiveTV: Loading live tv data from /var/lib/emby/data/livetv/timers
2020-06-11 10:31:07.394 Error App: Error downloading news
*** Error Report ***
Version: 4.4.3.0
Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb
Operating system: Unix 4.14.180.4
64-Bit OS: False
64-Bit Process: False
User Interactive: True
Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll
System.Environment.Version: 3.1.2
Processor count: 8
Program data path: /var/lib/emby
Application directory: /opt/emby-server/system
MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: ServiceUnavailable
at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod)
at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod)
at Emby.Server.Implementations.News.NewsEntryPoint.DownloadNews(String path)
at Emby.Server.Implementations.News.NewsEntryPoint.OnTimerFired(Object state)
Source: Emby.Server.Implementations
TargetSite: Void MoveNext()
2020-06-11 10:31:07.397 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.0459418 seconds
2020-06-11 10:31:07.397 Info App: Starting entry point Emby.LiveTV.LiveTVEntryPoint
2020-06-11 10:31:07.397 Info App: Entry point completed: Emby.LiveTV.LiveTVEntryPoint. Duration: 0.0005864 seconds
2020-06-11 10:31:07.397 Info App: Starting entry point Emby.LiveTV.RecordingNotifier
2020-06-11 10:31:07.401 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 0.0033448 seconds
2020-06-11 10:31:07.401 Info App: Starting entry point Emby.ActivityLog.ActivityLogEntryPoint
2020-06-11 10:31:07.406 Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.0051562 seconds
2020-06-11 10:31:07.406 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint
2020-06-11 10:31:07.410 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.0034824 seconds
2020-06-11 10:31:07.410 Info App: Starting entry point Emby.Notifications.Notifications
2020-06-11 10:31:07.411 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.0008429 seconds
2020-06-11 10:31:07.411 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint
2020-06-11 10:31:07.422 Info App: SyncRepository Initialize taking write lock
2020-06-11 10:31:07.422 Info App: SyncRepository Initialize write lock taken
2020-06-11 10:31:07.423 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0122213 seconds
2020-06-11 10:31:07.425 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint
2020-06-11 10:31:07.428 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.002983 seconds
2020-06-11 10:31:07.428 Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint
2020-06-11 10:31:07.429 Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 0.0007254 seconds
2020-06-11 10:31:07.429 Info App: All entry points have started
Yes, I have also made the request in the emby forum. Maybe the question can help somebody here too. Unfortunately there is no solution for the problem yet.
well ,I don’t see that much change for us to further assist, if even guys on emby forum are not able to fix it. I mean I’m not an emby specialist. But maybe there will be still someone around to continue investigation
