Odroid N2 + dietpi + odroid wifi module 5 a not working
https://github.com/MichaIng/DietPi/issues/4387
I followed the troubleshooting steps as mentioned above. The drivers are installed, the lights turn on and I get scan for wifi networks. Except I keep running into no DHCP answers. Any help would be much appreciated.
the issue you linked is still open and not solved. Therefore I did not expect a solution in it. As far as I can see, the issue is labelled as external issue and we are waiting on a kernel fix as DietPi did not do any kernel development.
Thanks. Wishful thinking that I may have missed something and there’d be a solution. Might check out an adapter with a different chipset.
