Node-RED Installation of node-red-node-serialport fails
Hi!
Running DietPi 8.2.2 with Node-RED 2.2.0 which I installed via dietpi-software, I have the following issue:
Installation of some Nodes like USBHID or serialport via >>pallettes<< fails. It also fails when I try to install it manually via “sudo npm install node-red-node-serialport”.
Now I don’t have any idea, what else I could do that it doesn’t fail anymore.
I know that this is not a node-red forum, but I think the problem is based on some access issues that I see from time to time while using Node-RED on DietPi. Maybe you have some hints for me?
Thanks in advance!
Florian
And here’s the logfile output…
0 verbose cli [
0 verbose cli   '/usr/local/bin/node',
0 verbose cli   '/usr/local/bin/npm',
0 verbose cli   'install',
0 verbose cli   '--no-audit',
0 verbose cli   '--no-update-notifier',
0 verbose cli   '--no-fund',
0 verbose cli   '--save',
0 verbose cli   '--save-prefix=~',
0 verbose cli   '--production',
0 verbose cli   '--engine-strict',
0 verbose cli   'node-red-node-serialport@1.0.1'
0 verbose cli ]
1 info using npm@8.5.5
2 info using node@v17.4.0
3 timing npm:load:whichnode Completed in 1ms
4 timing config:load:defaults Completed in 6ms
5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 2ms
6 timing config:load:builtin Completed in 3ms
7 verbose config production Use `--omit=dev` instead.
8 timing config:load:cli Completed in 9ms
9 timing config:load:env Completed in 1ms
10 timing config:load:project Completed in 26ms
11 timing config:load:file:/mnt/dietpi_userdata/node-red/.npmrc Completed in 0ms
12 timing config:load:user Completed in 1ms
13 timing config:load:file:/usr/local/etc/npmrc Completed in 0ms
14 timing config:load:global Completed in 1ms
15 timing config:load:validate Completed in 0ms
16 timing config:load:credentials Completed in 3ms
17 timing config:load:setEnvs Completed in 3ms
18 timing config:load Completed in 58ms
19 timing npm:load:configload Completed in 59ms
20 timing npm:load:setTitle Completed in 1ms
21 timing config:load:flatten Completed in 9ms
22 timing npm:load:display Completed in 11ms
23 verbose logfile /mnt/dietpi_userdata/node-red/.npm/_logs/2022-03-29T13_46_59_529Z-debug-0.log
24 timing npm:load:logFile Completed in 15ms
25 timing npm:load:timers Completed in 1ms
26 timing npm:load:configScope Completed in 0ms
27 timing npm:load Completed in 90ms
28 timing arborist:ctor Completed in 2ms
29 silly logfile start cleaning logs, removing 1 files
30 timing idealTree:init Completed in 3409ms
31 timing idealTree:userRequests Completed in 10ms
32 silly idealTree buildDeps
33 silly fetch manifest node-red-node-serialport@1.0.1
34 timing arborist:ctor Completed in 1ms
35 http fetch GET 200 https://registry.npmjs.org/node-red-node-serialport 3047ms (cache revalidated)
36 silly placeDep ROOT node-red-node-serialport@1.0.1 OK for:  want: 1.0.1
37 silly fetch manifest serialport@^10.3.0
38 http fetch GET 200 https://registry.npmjs.org/serialport 93ms (cache revalidated)
39 timing idealTree:#root Completed in 3193ms
40 silly placeDep node_modules/node-red-node-serialport serialport@10.4.0 OK for: node-red-node-serialport@1.0.1 want: ^10.3.0
41 silly fetch manifest @serialport/binding-mock@10.2.2
42 silly fetch manifest @serialport/bindings-cpp@10.7.0
43 silly fetch manifest @serialport/parser-byte-length@10.3.0
44 silly fetch manifest @serialport/parser-cctalk@10.3.0
45 silly fetch manifest @serialport/parser-delimiter@10.3.0
46 silly fetch manifest @serialport/parser-inter-byte-timeout@10.3.0
47 silly fetch manifest @serialport/parser-packet-length@10.3.0
48 silly fetch manifest @serialport/parser-readline@10.3.0
49 silly fetch manifest @serialport/parser-ready@10.3.0
50 silly fetch manifest @serialport/parser-regex@10.3.0
51 silly fetch manifest @serialport/parser-slip-encoder@10.3.0
52 silly fetch manifest @serialport/parser-spacepacket@10.3.0
53 silly fetch manifest @serialport/stream@10.3.0
54 silly fetch manifest debug@^4.3.3
55 http fetch GET 200 https://registry.npmjs.org/@serialport%2fbinding-mock 263ms (cache revalidated)
56 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-readline 332ms (cache revalidated)
57 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-inter-byte-timeout 359ms (cache revalidated)
58 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-delimiter 364ms (cache revalidated)
59 http fetch GET 200 https://registry.npmjs.org/debug 434ms (cache revalidated)
60 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-spacepacket 445ms (cache revalidated)
61 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-ready 453ms (cache revalidated)
62 http fetch GET 200 https://registry.npmjs.org/@serialport%2fstream 488ms (cache revalidated)
63 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-regex 496ms (cache revalidated)
64 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-cctalk 719ms (cache revalidated)
65 http fetch GET 200 https://registry.npmjs.org/@serialport%2fbindings-cpp 1223ms (cache revalidated)
66 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-byte-length 1625ms (cache revalidated)
67 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-slip-encoder 1659ms (cache revalidated)
68 http fetch GET 200 https://registry.npmjs.org/@serialport%2fparser-packet-length 1730ms (cache revalidated)
69 timing idealTree:node_modules/node-red-node-serialport Completed in 1764ms
70 silly placeDep node_modules/node-red-node-serialport @serialport/binding-mock@10.2.2 OK for: serialport@10.4.0 want: 10.2.2
71 silly placeDep ROOT @serialport/bindings-cpp@10.7.0 OK for: serialport@10.4.0 want: 10.7.0
72 silly placeDep node_modules/node-red-node-serialport @serialport/parser-byte-length@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
73 silly placeDep node_modules/node-red-node-serialport @serialport/parser-cctalk@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
74 silly placeDep node_modules/node-red-node-serialport @serialport/parser-delimiter@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
75 silly placeDep node_modules/node-red-node-serialport @serialport/parser-inter-byte-timeout@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
76 silly placeDep ROOT @serialport/parser-packet-length@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
77 silly placeDep node_modules/node-red-node-serialport @serialport/parser-readline@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
78 silly placeDep node_modules/node-red-node-serialport @serialport/parser-ready@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
79 silly placeDep node_modules/node-red-node-serialport @serialport/parser-regex@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
80 silly placeDep node_modules/node-red-node-serialport @serialport/parser-slip-encoder@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
81 silly placeDep ROOT @serialport/parser-spacepacket@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
82 silly placeDep node_modules/node-red-node-serialport @serialport/stream@10.3.0 OK for: serialport@10.4.0 want: 10.3.0
83 silly placeDep node_modules/node-red-node-serialport debug@4.3.4 OK for: serialport@10.4.0 want: ^4.3.3
84 silly fetch manifest @serialport/bindings-interface@^1.2.1
85 silly fetch manifest @serialport/bindings-interface@1.2.1
86 silly fetch manifest @serialport/parser-readline@^10.2.1
87 silly fetch manifest debug@^4.3.2
88 silly fetch manifest node-addon-api@^4.3.0
89 silly fetch manifest node-gyp-build@^4.3.0
90 silly fetch manifest ms@2.1.2
91 http fetch GET 200 https://registry.npmjs.org/node-gyp-build 77ms (cache revalidated)
92 http fetch GET 200 https://registry.npmjs.org/ms 81ms (cache revalidated)
93 http fetch GET 200 https://registry.npmjs.org/node-addon-api 86ms (cache revalidated)
94 http fetch GET 200 https://registry.npmjs.org/@serialport%2fbindings-interface 1406ms (cache revalidated)
95 timing idealTree:node_modules/node-red-node-serialport/node_modules/serialport Completed in 1540ms
96 silly placeDep ROOT @serialport/bindings-interface@1.2.1 OK for: @serialport/bindings-cpp@10.7.0 want: 1.2.1
97 silly placeDep node_modules/@serialport/bindings-cpp @serialport/parser-readline@10.3.0 OK for: @serialport/bindings-cpp@10.7.0 want: ^10.2.1
98 silly placeDep node_modules/@serialport/bindings-cpp debug@4.3.4 OK for: @serialport/bindings-cpp@10.7.0 want: ^4.3.2
99 silly placeDep node_modules/@serialport/bindings-cpp node-addon-api@4.3.0 OK for: @serialport/bindings-cpp@10.7.0 want: ^4.3.0
100 silly placeDep ROOT node-gyp-build@4.3.0 OK for: @serialport/bindings-cpp@10.7.0 want: ^4.3.0
101 timing idealTree:node_modules/@serialport/bindings-cpp Completed in 43ms
102 timing idealTree:node_modules/@serialport/bindings-interface Completed in 1ms
103 timing idealTree:node_modules/@serialport/parser-packet-length Completed in 0ms
104 timing idealTree:node_modules/@serialport/parser-spacepacket Completed in 0ms
105 timing idealTree:node_modules/node-gyp-build Completed in 0ms
106 silly placeDep node_modules/@serialport/bindings-cpp @serialport/parser-delimiter@10.3.0 OK for: @serialport/parser-readline@10.3.0 want: 10.3.0
107 timing idealTree:node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-readline Completed in 6ms
108 timing idealTree:node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-delimiter Completed in 0ms
109 silly placeDep node_modules/@serialport/bindings-cpp ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
110 timing idealTree:node_modules/@serialport/bindings-cpp/node_modules/debug Completed in 5ms
111 timing idealTree:node_modules/@serialport/bindings-cpp/node_modules/ms Completed in 0ms
112 timing idealTree:node_modules/@serialport/bindings-cpp/node_modules/node-addon-api Completed in 0ms
113 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/binding-mock Completed in 0ms
114 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/parser-byte-length Completed in 0ms
115 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/parser-cctalk Completed in 0ms
116 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/parser-delimiter Completed in 0ms
117 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/parser-inter-byte-timeout Completed in 0ms
118 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/parser-readline Completed in 0ms
119 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/parser-ready Completed in 0ms
120 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/parser-regex Completed in 0ms
121 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/parser-slip-encoder Completed in 0ms
122 timing idealTree:node_modules/node-red-node-serialport/node_modules/@serialport/stream Completed in 0ms
123 silly placeDep node_modules/node-red-node-serialport ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
124 timing idealTree:node_modules/node-red-node-serialport/node_modules/debug Completed in 4ms
125 timing idealTree:node_modules/node-red-node-serialport/node_modules/ms Completed in 0ms
126 timing idealTree:buildDeps Completed in 6572ms
127 timing idealTree:fixDepFlags Completed in 38ms
128 timing idealTree Completed in 10071ms
129 timing reify:loadTrees Completed in 10074ms
130 timing reify:diffTrees Completed in 143ms
131 silly reify moves {}
132 timing reify:retireShallow Completed in 1ms
133 timing reify:createSparse Completed in 19ms
134 timing reify:trashOmits Completed in 4ms
135 timing reify:loadBundles Completed in 0ms
136 verbose reify failed optional dependency /mnt/dietpi_userdata/node-red/node_modules/fsevents
137 silly reify mark deleted [ '/mnt/dietpi_userdata/node-red/node_modules/fsevents' ]
138 timing reifyNode:node_modules/fsevents Completed in 13ms
139 timing reifyNode:node_modules/@serialport/bindings-cpp/node_modules/ms Completed in 327ms
140 timing reifyNode:node_modules/node-red-node-serialport/node_modules/ms Completed in 327ms
141 timing reifyNode:node_modules/@serialport/parser-packet-length Completed in 338ms
142 timing reifyNode:node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-delimiter Completed in 339ms
143 timing reifyNode:node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-readline Completed in 337ms
144 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/parser-regex Completed in 338ms
145 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/parser-ready Completed in 339ms
146 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/parser-inter-byte-timeout Completed in 338ms
147 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/parser-readline Completed in 340ms
148 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/parser-delimiter Completed in 339ms
149 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/parser-cctalk Completed in 339ms
150 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/parser-byte-length Completed in 340ms
151 timing reifyNode:node_modules/node-gyp-build Completed in 348ms
152 timing reifyNode:node_modules/@serialport/bindings-interface Completed in 348ms
153 timing reifyNode:node_modules/@serialport/parser-spacepacket Completed in 348ms
154 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/binding-mock Completed in 345ms
155 timing reifyNode:node_modules/@serialport/bindings-cpp/node_modules/debug Completed in 349ms
156 timing reifyNode:node_modules/node-red-node-serialport/node_modules/debug Completed in 348ms
157 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/stream Completed in 347ms
158 timing reifyNode:node_modules/node-red-node-serialport/node_modules/@serialport/parser-slip-encoder Completed in 349ms
159 timing reifyNode:node_modules/node-red-node-serialport/node_modules/serialport Completed in 350ms
160 timing reifyNode:node_modules/node-red-node-serialport Completed in 363ms
161 timing reifyNode:node_modules/@serialport/bindings-cpp/node_modules/node-addon-api Completed in 378ms
162 timing reifyNode:node_modules/@serialport/bindings-cpp Completed in 430ms
163 timing reify:unpack Completed in 431ms
164 timing reify:unretire Completed in 0ms
165 timing build:queue Completed in 7ms
166 timing build:link:node_modules/node-gyp-build Completed in 4ms
167 timing build:link Completed in 5ms
168 info run @serialport/bindings-cpp@10.7.0 install node_modules/@serialport/bindings-cpp node-gyp-build
169 info run @serialport/bindings-cpp@10.7.0 install { code: 126, signal: null }
170 timing reify:rollback:createSparse Completed in 149ms
171 timing reify:rollback:retireShallow Completed in 0ms
172 timing command:install Completed in 10922ms
173 verbose stack Error: command failed
173 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/index.js:64:27)
173 verbose stack     at ChildProcess.emit (node:events:520:28)
173 verbose stack     at maybeClose (node:internal/child_process:1090:16)
173 verbose stack     at Socket.<anonymous> (node:internal/child_process:449:11)
173 verbose stack     at Socket.emit (node:events:520:28)
173 verbose stack     at Pipe.<anonymous> (node:net:687:12)
174 verbose pkgid @serialport/bindings-cpp@10.7.0
175 verbose cwd /mnt/dietpi_userdata/node-red
176 verbose Linux 5.10.103-v8+
177 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "--no-audit" "--no-update-notifier" "--no-fund" "--save" "--save-prefix=~" "--production" "--engine-strict" "node-red-node-serialport@1.0.1"
178 verbose node v17.4.0
179 verbose npm  v8.5.5
180 error code 126
181 error path /mnt/dietpi_userdata/node-red/node_modules/@serialport/bindings-cpp
182 error command failed
183 error command sh -c node-gyp-build
184 error sh: 1: node-gyp-build: Permission denied
185 verbose exit 126
186 timing npm Completed in 11615ms
187 verbose unfinished npm timer reify 1648561620214
188 verbose unfinished npm timer reify:build 1648561630909
189 verbose unfinished npm timer build 1648561630912
190 verbose unfinished npm timer build:deps 1648561630912
191 verbose unfinished npm timer build:run:install 1648561630926
192 verbose unfinished npm timer build:run:install:node_modules/@serialport/bindings-cpp 1648561630927
193 verbose code 126
194 error A complete log of this run can be found in:
194 error     /mnt/dietpi_userdata/node-red/.npm/_logs/2022-03-29T13_46_59_529Z-debug-0.log
I have no knowledge about node-red, but when I look into the log I see this
so it’s a permission issue.
I found some kind related thread on stackoverflow: https://stackoverflow.com/questions/71462333/fail-to-install-gatsby-cil-npm-err-sh-1-node-gyp-build-permission-denied
And there is another error at line 173, but IDK nothing about this.
Maybe it’s also worth looking into the log mentioned at the last line.
In the meantime I figured out, that the problem obviously started with the last update to Version > 8.1.2.
Until 8.1.2 I am able to install serialport without any issues.
I think I will take the time to find out, if it has something to do with the update itself, or if there is any other changes, that I made the same time…
There was no change related to Node-Red on the last update https://github.com/MichaIng/DietPi/blob/master/CHANGELOG.txt
Usually we don’t do any update on already installed software. Maybe there was an update of the node package themself?
Anyway. Have a look to /mnt/dietpi_userdata/node-red/node_modules/@serialport/. It should belong to nodered user to allow r/w operation
