Running dietpi on RPI3b+ for years now, couple of months ago upgraded to bookworm, no issues.
after recent (5days ago) dietpi-update to 9.10 it seems it broken somehow GPIO communication to the Node-RED.
Initially it shown “stopped” with red under the gpio block in node-red, after some tryouts it now saying OK under the GPIO block, but it’s yellow - so it’s not comunnicating properly.
sadly (my bad) I can’t roll update back as I have backup after update ![]()
Not really sure what to look for, as it was working just fine for years now.
what I’ve tried is to:
install pigpiod (no luck)
reinstall rpi.gpio
reinstall node-red
upgrade node-red
run node-red as root
There are no errors in the node-red log.
Has something changed in 9.10 dietpi?
Someone who points me to the right direction will be really appreciated ![]()
update:
on other rpi which runs DHT sensor i2c, and PIR sensor on some pin, I can see same issue with communication with gpio:
sudo python3 scripts/climate.py
/usr/local/lib/python3.11/dist-packages/gpiozero/devices.py:300: PinFactoryFallback: Falling back from lgpio: No module named 'lgpio'
warnings.warn(
File "/home/dietpi/scripts/climate.py", line 22, in <module>
pir_sensor = DigitalInputDevice(24)
File "/usr/local/lib/python3.11/dist-packages/gpiozero/devices.py", line 108, in __call__
self = super().__call__(*args, **kwargs)
File "/usr/local/lib/python3.11/dist-packages/gpiozero/input_devices.py", line 168, in __init__
self.pin.when_changed = self._pin_changed
File "/usr/local/lib/python3.11/dist-packages/gpiozero/pins/__init__.py", line 471, in <lambda>
lambda self, value: self._set_when_changed(value),
File "/usr/local/lib/python3.11/dist-packages/gpiozero/pins/pi.py", line 639, in _set_when_changed
self._enable_event_detect()
File "/usr/local/lib/python3.11/dist-packages/gpiozero/pins/rpigpio.py", line 220, in _enable_event_detect
GPIO.add_event_detect(
RuntimeError: Failed to add edge detection
So i guess it must be related to the 9.10 release of the Dietpi @MichaIng ?
