No internet after power outage
# This is /run/systemd/resolve/resolv.conf managed by man:systemd-resolved(8).
# Do not edit.
# This file might be symlinked as /etc/resolv.conf. If you're looking at
# /etc/resolv.conf and seeing this text, you have followed the symlink.
# This is a dynamic resolv.conf file for connecting local clients directly to
# all known uplink DNS servers. This file lists all configured search domains.
# Third party programs should typically not access this file directly, but only
# through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a
# different way, replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
# No DNS servers known.
search .
For whatever reason you have installed systemd-resolved. This is not needed at all. Maybe something that OMV comes with? If possible, you should uninstall it as you are using STATIC IP.
I don’t know :confused: Just installed diepi, nginx and openmediavault.
For what is it?
I’m using DCHP, dietpi gets the ip from my router
/edit
maybe systemd-resolved is from docker I installed with openmediavault?
systemd-resolved is a systemd service that provides network name resolution to local applications via a D-Bus interface.
At least from our side, it is not installed and not required.
The screenshot above says something different. It said SATIC and not DHCP.
So, what must I do to uninstall it and get my name resolution back?
Quoting myself
just apt remove systemd-resolved and DNS name resolution might be working?
Check content of /etc/resolv.conf after removing the package. It should continue the DNS server provided by your DHCP server
cat: /etc/resolv.conf: No such file or directory
hm no name resolution :frowning:
Switch to static ip once, and back to DHCP. Does it generate the file?
No.
 - Command: curl -ILfvm 10 https://dietpi.com/
mawk: cannot open /etc/resolv.conf (No such file or directory)
[  OK  ] DietPi-Config | sed --follow-symlinks -i / iw dev .* set power_save /d /etc/network/interfaces
[ SUB1 ] DietPi-Set_hardware > wifimodules (disable)
[  OK  ] DietPi-Set_hardware | Desired setting in /boot/config.txt was already set: dtoverlay=disable-wifi
[  OK  ] DietPi-Set_hardware | eval echo 'blacklist brcmutil' >> /etc/modprobe.d/dietpi-disable_wifi.conf
[  OK  ] DietPi-Set_hardware | modprobe -rf brcmutil
[  OK  ] DietPi-Set_hardware | eval echo 'blacklist brcmfmac' >> /etc/modprobe.d/dietpi-disable_wifi.conf
[  OK  ] DietPi-Set_hardware | modprobe -rf brcmfmac
[  OK  ] DietPi-Set_hardware | eval echo 'blacklist cfg80211' >> /etc/modprobe.d/dietpi-disable_wifi.conf
[  OK  ] DietPi-Set_hardware | modprobe -rf cfg80211
[  OK  ] wifimodules disable | Completed
[ INFO ] DietPi-Config | Restarting network connections, please wait...
[  OK  ] DietPi-Config | systemctl daemon-reload
[ INFO ] DietPi-Config | systemctl restart ifup@eth0, please wait...
Apr 18 15:07:17 DietPi systemd[1]: Stopping ifup@eth0.service - ifup for eth0...
Apr 18 15:07:17 DietPi dhclient[2803]: Removed stale PID file
Apr 18 15:07:17 DietPi ifdown[2803]: Removed stale PID file
Apr 18 15:07:17 DietPi ifdown[2803]: Internet Systems Consortium DHCP Client 4.4.3-P1
Apr 18 15:07:17 DietPi ifdown[2803]: Copyright 2004-2022 Internet Systems Consortium.
Apr 18 15:07:17 DietPi ifdown[2803]: All rights reserved.
Apr 18 15:07:17 DietPi ifdown[2803]: For info, please visit https://www.isc.org/software/dhcp/
Apr 18 15:07:17 DietPi dhclient[2803]: Internet Systems Consortium DHCP Client 4.4.3-P1
Apr 18 15:07:17 DietPi dhclient[2803]: Copyright 2004-2022 Internet Systems Consortium.
Apr 18 15:07:17 DietPi dhclient[2803]: All rights reserved.
Apr 18 15:07:17 DietPi dhclient[2803]: For info, please visit https://www.isc.org/software/dhcp/
Apr 18 15:07:17 DietPi dhclient[2803]: Listening on LPF/eth0/2c:cf:67:d4:3a:a0
Apr 18 15:07:17 DietPi ifdown[2803]: Listening on LPF/eth0/2c:cf:67:d4:3a:a0
Apr 18 15:07:17 DietPi ifdown[2803]: Sending on   LPF/eth0/2c:cf:67:d4:3a:a0
Apr 18 15:07:17 DietPi ifdown[2803]: Sending on   Socket/fallback
Apr 18 15:07:17 DietPi dhclient[2803]: Sending on   LPF/eth0/2c:cf:67:d4:3a:a0
Apr 18 15:07:17 DietPi dhclient[2803]: Sending on   Socket/fallback
Apr 18 15:07:17 DietPi dhclient[2803]: DHCPRELEASE of 192.168.1.65 on eth0 to 192.168.1.1 port 67
Apr 18 15:07:17 DietPi ifdown[2803]: DHCPRELEASE of 192.168.1.65 on eth0 to 192.168.1.1 port 67
Apr 18 15:07:17 DietPi systemd[1]: ifup@eth0.service: Deactivated successfully.
Apr 18 15:07:17 DietPi systemd[1]: Stopped ifup@eth0.service - ifup for eth0.
Apr 18 15:07:17 DietPi systemd[1]: Starting ifup@eth0.service - ifup for eth0...
Apr 18 15:07:17 DietPi dhclient[2840]: Internet Systems Consortium DHCP Client 4.4.3-P1
Apr 18 15:07:17 DietPi ifup[2840]: Internet Systems Consortium DHCP Client 4.4.3-P1
Apr 18 15:07:17 DietPi ifup[2840]: Copyright 2004-2022 Internet Systems Consortium.
Apr 18 15:07:17 DietPi ifup[2840]: All rights reserved.
Apr 18 15:07:17 DietPi ifup[2840]: For info, please visit https://www.isc.org/software/dhcp/
Apr 18 15:07:17 DietPi dhclient[2840]: Copyright 2004-2022 Internet Systems Consortium.
Apr 18 15:07:17 DietPi dhclient[2840]: All rights reserved.
Apr 18 15:07:17 DietPi dhclient[2840]: For info, please visit https://www.isc.org/software/dhcp/
Apr 18 15:07:17 DietPi dhclient[2840]: Listening on LPF/eth0/2c:cf:67:d4:3a:a0
Apr 18 15:07:17 DietPi ifup[2840]: Listening on LPF/eth0/2c:cf:67:d4:3a:a0
Apr 18 15:07:17 DietPi ifup[2840]: Sending on   LPF/eth0/2c:cf:67:d4:3a:a0
Apr 18 15:07:17 DietPi ifup[2840]: Sending on   Socket/fallback
Apr 18 15:07:17 DietPi dhclient[2840]: Sending on   LPF/eth0/2c:cf:67:d4:3a:a0
Apr 18 15:07:17 DietPi ifup[2840]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
Apr 18 15:07:17 DietPi dhclient[2840]: Sending on   Socket/fallback
Apr 18 15:07:17 DietPi dhclient[2840]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
Apr 18 15:07:20 DietPi dhclient[2840]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
Apr 18 15:07:20 DietPi ifup[2840]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
[  OK  ] DietPi-Config | systemctl restart ifup@eth0
[ INFO ] DietPi-Config | Reloading networking data, please wait...
[  OK  ] DietPi-Config | Network restarted
[      ] DietPi-Config | Checking URL: https://dietpi.com/ (2/2)  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0* Could not resolve host: dietpi.com
* Closing connection 0
curl: (6) Could not resolve host: dietpi.com
[FAILED] DietPi-Config | Checking URL: https://dietpi.com/
root@DietPi:~# cat /etc/resolv.conf
Create it manually and try again
touch /etc/resolv.conf
touch: cannot touch '/etc/resolv.conf': No such file or directory
Do you use root user to do this?
Yes
Maybe resolv.conf is a symlink?
Try to remove it and touch again.
sudo rm -f /etc/resolv.conf
sudo touch /etc/resolv.conf
That worked! Thank you so much guys!
One more question, I just saw when I install openmediavault it will install systemd-resolved. Is there a way to bypass the DNS problem?
When you install OMV:
  • /etc/resolv.conf becomes a symlink to /run/systemd/resolve/stub-resolv.conf
  • DNS queries go to 127.0.0.53
To avoid conflicts, you can do the following after the installation of OMV:
sudo systemctl disable systemd-resolved
sudo systemctl stop systemd-resolved
And then set a DNS server for this device via dietpi-config or by editing /etc/resolv.conf directly.
If you wanna stay with systemd-resolved, you can config /etc/systemd/resolved.conf properly and restart systemd-resolved service.
