DietPi v157 and Allo Web GUI on RPI. installation OK, Thank’s …
Only issue is using Shairport-Sync: No audio from my DAC, but DietPi AIrPlay endpoint seen from Itunes and IOS devices.
I’ve set output to 44100 / 32 bits via Web GUI but audio still KO.
If i disable Shairport from web GUI and launch Shairport from command line audio is playing correctly:
> root@DietPi:~# shairport-sync -vvv
Looking for configuration file at full path "/usr/local/etc/shairport-sync.conf"
Value read for output rate is 44100.
alsa output device name is "default".
The processor is running little-endian.
Audio OK
Here is my conf from /usr/local/etc/shairport-sync.conf:
No errors when services are restarted via dietpi-services restart,
No errors on shairport-sync status,
No errors in Itunes UI (DietPi endpoint is displayed and audio progress bar moving)
But no Audio stream sent to my DAC and Allo GUi ALSA status is blank.
root@DietPi:/usr/local/etc# systemctl status shairport-sync -l
● shairport-sync.service - Shairport Sync - AirPlay Audio Receiver
Loaded: loaded (/lib/systemd/system/shairport-sync.service; disabled)
Active: active (running) since Fri 2017-10-20 21:38:17 UTC; 10min ago
Main PID: 14522 (shairport-sync)
CGroup: /system.slice/shairport-sync.service
└─14522 /usr/local/bin/shairport-sync
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
If Shairport is disabled from Allo GUI and launched from command line Audio output is OK
Strange !
Hi, same problem for me , no sound since last update with squeezelite (with Rpi3 and Allo USBridge).
With Roon bridge no problem at all, audio is back;
I have an Fostex HPA8 Dac.
Thx in advance.
