I have Nginx as default web server and installed Ampache.
Now when I open 192.168.100/ampache I am redirected to http://dietpi/ampache/login.php and says “Address Not Found”
Why is ip in URL replaced with host name? I am planing to use in local network only.
Ok I found it. Basically you would need to adjust Nginx config file
nano /etc/nginx/sites-available/default
Change server_name “$hostname”; into server_name “<192.168.x.x>”;
Replace IP address with the one from your DietPi device. Once done, restart your web server
server {
# listen to
listen 80 default_server; #ssl; ipv6 optional with ssl enabled
listen [::]:80 default_server; #ssl; ipv4 optional with ssl enabled
server_name 192.168.1.100;
charset utf-8;
# Logging, error_log mode [notice] is necessary for rewrite_log on,
# (very usefull if rewrite rules do not work as expected)
access_log /var/log/nginx/ampache.access.log; # notice;
# error_log /var/log/nginx/ampache.error.log;
# rewrite_log on;
# Use secure SSL/TLS settings, see https://mozilla.github.io/server-side-tls/ssl-config-generator/
# ssl_protocols TLSv1.2;
# ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-E CDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256';
# ssl_prefer_server_ciphers on;
# add_header Strict-Transport-Security max-age=15768000;
# etc.
# Use secure headers to avoid XSS and many other things
# add_header X-Content-Type-Options nosniff;
# add_header X-XSS-Protection "1; mode=block";
# add_header X-Robots-Tag none;
# add_header X-Download-Options noopen;
# add_header X-Permitted-Cross-Domain-Policies none;
# add_header X-Frame-Options "SAMEORIGIN" always;
# add_header Referrer-Policy "no-referrer";
# add_header Content-Security-Policy "script-src 'self' 'unsafe-inline' 'unsafe-eval'; frame-src 'self'; object-src 'self'";
# Avoid information leak
# server_tokens off;
#fastcgi_hide_header X-Powered-By;
root /var/www/ampache;
index index.php;
# Somebody said this helps, in my setup it doesn't prevent temporary saving in files
# proxy_max_temp_file_size 0;
# Rewrite rule for Subsonic backend
if ( !-d $request_filename ) {
rewrite ^/rest/(.*).view$ /rest/index.php?action=$1 last;
rewrite ^/rest/fake/(.+)$ /play/$1 last;
# Rewrite rule for Channels
if (!-d $request_filename){
rewrite ^/channel/([0-9]+)/(.*)$ /channel/index.php?channel=$1&target=$2 last;
# Beautiful URL Rewriting
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&name=$5 last;
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/client/(.*)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&client=$5&name=$6 last;
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/client/(.*)/player/(.*)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&client=$5&player=$6&name=$7 last;
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/client/(.*)/bitrate/([0-9]+)/player/(.*)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&client=$5&bitrate=$6player=$7&name=$8 last;
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/client/(.*)/transcode_to/(w+)/bitrate/([0-9]+)/player/(.*)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&client=$5&transcode_to=$6&bitrate=$7&player=$8&name=$9 last;
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/client/(.*)/noscrobble/([0-1])/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&client=$5&noscrobble=$6&name=$7 last;
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/client/(.*)/noscrobble/([0-1])/player/(.*)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&client=$5&noscrobble=$6&player=$7&name=$8 last;
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/client/(.*)/noscrobble/([0-1])/bitrate/([0-9]+)/player/(.*)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&client=$5&noscrobble=$6&bitrate=$7player=$8&name=$9 last;
rewrite ^/play/ssid/(\w+)/type/(\w+)/oid/([0-9]+)/uid/([0-9]+)/client/(.*)/noscrobble/([0-1])/transcode_to/(w+)/bitrate/([0-9]+)/player/(.*)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4&client=$5&noscrobble=$6&transcode_to=$7&bitrate=$8&player=$9&name=$10 last;
# the following line was needed for me to get downloads of single songs to work
rewrite ^/play/ssid/(.*)/type/(.*)/oid/([0-9]+)/uid/([0-9]+)/action/(.*)/name/(.*)$ /play/index.php?ssid=$1&type=$2&oid=$3&uid=$4action=$5&name=$6 last;
location /play {
if (!-e $request_filename) {
rewrite ^/play/art/([^/]+)/([^/]+)/([0-9]+)/thumb([0-9]*)\.([a-z]+)$ /image.php?object_type=$2&object_id=$3&auth=$1 last;
rewrite ^/([^/]+)/([^/]+)(/.*)?$ /play/$3?$1=$2;
rewrite ^/(/[^/]+|[^/]+/|/?)$ /play/index.php last;
break;
location /rest {
limit_except GET POST {
deny all;
location ^~ /bin/ {
deny all;
return 403;
location ^~ /config/ {
deny all;
return 403;
location / {
limit_except GET POST HEAD{
deny all;
#location ~ ^/.*.php {
location ~ \.php(?:$|/) {
include snippets/fastcgi-php.conf;
fastcgi_pass php;
try_files $uri = 404;
# chose as your php-fpm is configured to listen on
fastcgi_pass unix:/var/run/php5-fpm.sock;
# fastcgi_pass 127.0.0.1:8000/;
fastcgi_index index.php;
fastcgi_param PHP_ADMIN_VALUE "open_basedir=/tmp/:/var/www/ampache/:/var/log:/usr/bin";
include /etc/nginx/fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root/$fastcgi_script_name;
# sets the timeout for requests in [s] , 60s are normally enough
# fastcgi_read_timeout 60s;
# Mitigate HTTPOXY https://httpoxy.org/
fastcgi_param HTTP_PROXY "";
# has to be set to on if encryption (https) is used:
# fastcgi_param HTTPS on;
# fastcgi_split_path_info ^(.+?\.php)(/.*)$;
# Rewrite rule for WebSocket
location /ws {
rewrite ^/ws/(.*) /$1 break;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header Host $host;
proxy_pass http://127.0.0.1:8100/;
named the file as ampache and placed it in /etc/nginx/sites-enabled
(sites-enabled contain two files. ampache and default)
now restarting nginx failed.
removed the default file and tried restarting nginx but still failed.
ok I got it working. BUT using this configuration will manipulate Nginx away from DietPi standard and Nginx will be useable for Ampache only. Because you will have document root pointing directly to Ampache. Means, other web applications can’t be used anymore.
You would need 2 files to adjusted and one sym link to be removed (if still present)
rm /etc/nginx/sites-enabled/default
nano /etc/nginx/sites-enabled/ampache
Add
server {
# listen to
server_name 192.168.0.17;
charset utf-8;
# rewrite_log on;
# etc.
index index.php;
location /play {
break;
location /rest {
deny all;
location ^~ /bin/ {
deny all;
return 403;
deny all;
return 403;
location / {
deny all;
try_files $uri $uri/ =404;
fastcgi_pass php;
location /ws {
disclaimer: I’m not an Ampache specialist and I’m not sure if all these changes are working as expected. I never used Ampache myself. I fixed the Nginx errors only, that showed up on the error.log
Strange, that server_name should only be relevant Nginx internally in case one is running multiple servers, so they can be identified. Using an IP address there is not foreseen and I cannot find any hint that it is used for redirects. I mean you can assign a wildcard there, how would the rewrite then look like?
Either hostname or none is the correct server_name I’d say, so we need to find the reason why even a default directory index is rewritten to server_name and disable that.
It is not an issue with the Nginx configuration but with Ampache PHP scripts. Any other page index and rewrites do not suffer from this, so the Nginx config works as expected. By default Nginx passes the server name to PHP handler via fastcgi_param SERVER_NAME $server_name;, pretty common with other webservers as well. I commented that (in /etc/nginx/fastcgi.conf) and now every non-explicit access to Ampache is redirected to http://ampache/whichever.php, the same happens when instead unsetting server_name (so that it is in fact an empty string).
Here it can be fixed: https://github.com/ampache/ampache/blob/develop/lib/init.php#L86
Replacing SERVER_NAME with HOST_NAME in this line solves the issue, probably it is required in a few other cases as well. While SERVER_NAME usually should match the FQDN of the server, it is not reliable and sometimes not possible. HTTP_HOST simply matches the hostname or IP whichever the client accessed the server with, hence using that is safest as the existing request is not changed. I’ll open an issue at Ampache to make this a topic.
Jep makes sense. The .htaccess files are installed correctly, but security headers make sense and for other webservers additionally the access permissions.
I want to use it along with pihole.
I am able to run Ampache but not able to configure it for subsonic backend and upnp backend. I have been searching all over the internet for Lighttpd or Nginx but no success. I have no knowledge of webservers. Ampache wiki page provides help for configuring different servers but I am clue less on which file and their location.
Could you guys autoconfigure servers based on ampache wiki while installing Ampache from dietpi-software.
