Nextcloud is installed on my RPi3 B using DietPi and works perfectly.
Now I’ve noticed that there are 2 messages about problems that I can’t solve without help.
Below is the text: - Sorry, it’s a translation from German.
There are some warnings in your system configuration.
1.) You are currently using PHP 7.4.33. We recommend upgrading your PHP version to take advantage of the speed and security updates provided by the PHP group↗ once your distribution supports them.
2.) The PHP OPcache module is not configured correctly. See the documentation
for more information.
The OPcache internal string cache is almost full. To ensure that repeated strings can be cached effectively, it is recommended to apply opcache.interned_strings_buffer with a value greater than 8 in your PHP configuration.
How can I fix these problems?
Best regards
