Hi everyone.
New DietPi user, bit of a Linux noob but I’m learning fast. DietPi has made so much accessible - really nice solution. Well done devs.
I have a 4GB Pi4 running DietPi 6.28 with NextCloud 18.03 on Nginx, SAMBA and some other utilities. Works really well out of the box, very pleased. I don’t store any files inside NextCloud per se, I use it an Internet facing Web portal for a QNAP NAS I have running on the same network. I’m using the External Storage feature in NextCloud to connect to an SMB share. That’s all connected and working fine. I can browse the share and see all its Files inside Nextcloud no problem. I regularly share files stored on this SMB share via NextCloud and this is where the problem lies.
I can share out any file for download without issue. The problem is with large files. Any file over 1GB in size literally only download the first 1GB and then stops. Any file under 1GB downloads fine, its just files over 1GB. The download stalls at exactly the 1GB mark. Its like I’m hitting a limit somewhere.
If I upload the same file into Nextcloud so that its stored in its Data directory the full file will download without issue so seems to be sharing files stored on an SMB source that’s the problem.
I can see someone else having exactly the same issue but without any resolution mentioned.
https://help.nextcloud.com/t/nextcloud-external-storage-download-large-file/63745/2
Anyone here have any ideas?
