Netdata clean installation, not starting
  • DietPi version | 8.9.2
  • Distro version | bullseye
  • Kernel version | Linux DietPi 5.10.144-meson64 #22.08.2 SMP PREEMPT Wed Sep 21 19:02:36 UTC 2022 aarch64 GNU/Linux
  • SBC model | Odroid HC4)
  • Power supply used | 5V 1A RAVpower
  • SD card used | SanDisk ultra
  • Software title | Netdata
  • Installed freshly
  • Can this issue be replicated on a fresh installation of DietPi? Don’t know..
  1. …Install Netdata
  2. …Access localhost:19999
  • Application starts
  • Unable to connect
Firefox can’t establish a connection to the server at localhost:19999.
  • Service is running fine
Output details of journalctl -u netdata
Oct 05 09:06:29 DietPi systemd[1]: Started netdata - Real-time performance monit
oring.
Oct 05 09:06:29 DietPi netdata[2264]: CONFIG: cannot load cloud config '/var/lib
/netdata/cloud.d/cloud.conf'. Running with internal defaults.
Oct 05 09:06:29 DietPi netdata[2264]: 2022-10-05 09:06:29: netdata INFO  : MAIN
: CONFIG: cannot load cloud config '/var/lib/netdata/cloud.d/cloud.conf'. Runnin
Oct 05 09:06:29 DietPi netdata[2264]: SIGNAL: Not enabling reaper
Sorry, had to comment this line to work on local
bind socket to IP = 127.0.0.1
By the way first access to netdata.conf was empty, I’d run the script edit-config on /etc/netdata to show the content on netdata.conf
