Kernel version | Linux Dietpi 6.1.21-v8+ #1642 SMP PREEMPT aarch64
Architecture | arm64
SBC model | RPi4 Model B
Internet completely stopped working.
Ethernet connection says available - on - disconnected. Same for wifi. Onboard wifi is on, but SSID scanning is not working, cause “no wifi adapter was detected on your device”. Ethernet is plugged in, I tried two different cables, but it fails to connect.
And it just randomly stopped working. It used to work before, with Ethernet. Wifi I almost never tried since years I own the raspberry I guess. The only thing I can’t think of is that it stopped working after updating Dietpi version, but I’m not sure about it, even though I cannot think of any other operation I did on the system.
I’m also fine with resetting if it’s a reasonable option.
In case I’m missing some details I’m sorry, I’ll gladly send them if needed
Do you see LED activity on the network adapter when you plug in a cable? Can you reboot your system and check the following (assuming the Ethernet is connected)
This is WiFi, sorry for the screenshots but I don’t have ssh so no way to copy paste and WiFi is not important (I would like to fix it but my main connection for the rasp is via Ethernet)
Hi, thank you for your answer.
Yes, both green and orange LEDs turn on.
I forgot to mention, maybe it’s important, at the startup I get the message “A start job is running for ifup for eth0” (and wlan0 as well, they swap like every second).
This goes on for a while, slowing down the boot process, and after a while just loads the terminal as it should, with internet not working ofc.
This is my output from the command (sorry for the photo but I have no ssh to copy paste ;(
P.S.
I just recalled now that I booted the raspberry again that whenever my autostart script starts, I get the message:
"chmod: changing permissions of ‘/var/lib/dietpi/dietpi-autostart/custom.sh’: Operation not permitted
Doesn’t seem to affect the actual startup script, but still I take the chance to mention it.
Unfortunately, SD cards are not that reliable and designed for 24/7 operation. Especially cheap ones. If using the RPi4, you could think about booting from a USB-connected device or take a look at the RaspiKey as an eMMC flash device.
I had some micro USB pen drives in past but after 2 years they got slower and slower on write operations. Therefore I switched to RaspiKey. But usually a USB stick should fine as well.
