tor.service - Anonymizing overlay network for TCP (multi-instance-master)
Loaded: loaded (/lib/systemd/system/tor.service; enabled; preset: enabled)
Active: active (exited) since Tue 2023-12-12 07:02:13 CET; 3s ago
Process: 1776 ExecStart=/bin/true (code=exited, status=0/SUCCESS)
Main PID: 1776 (code=exited, status=0/SUCCESS)
CPU: 4ms
Dez 12 07:02:13 pihole systemd[1]: Starting tor.service - Anonymizing overlay network for TCP (multi-instance-master)...
Dez 12 07:02:13 pihole systemd[1]: Finished tor.service - Anonymizing overlay network for TCP (multi-instance-master).
It always exit directly…but why?
I see this warning in the log
Dec 12 08:28:10.955 [warn] Configuration port ORPort 81 superseded by ORPort [2a02:8070:2482:4560:2c91:65ff:fed9:fc7f]:81
Dec 12 08:28:10.956 [warn] Configuration port ORPort 81 superseded by ORPort 0.0.0.0:81
Dec 12 08:28:10.956 [warn] Your ContactInfo config option is not set. Please strongly consider setting it, so we can contact you if your relay is misconfigured, end-of-life, or something else goes wrong. It is also possible that your relay might get rejected from the network due to a missing valid contact address.
Dec 12 08:28:10.959 [warn] Configuration port ORPort 81 superseded by ORPort [ipv6address]:81
Dec 12 08:28:10.959 [warn] Configuration port ORPort 81 superseded by ORPort 0.0.0.0:81
Dec 12 08:28:10.000 [warn] Your log may contain sensitive information - you're logging more than "notice". Don't log unless it serves an important reason. Overwrite the log afterwards.
well the error might be kicking the tor relay out…go into settings and make sure you put in correct address, or change it to a valid one
I always use me@nope.com
