I’m trying to set up a staging environment on my Raspberry Pi for a NodeJS app that uses MongoDB for the database.
The issue is that the connector library for NodeJS requires a version of MongoDB more recent than what’s installed through a simple “apt-get install mongodb-server” (v2.4.14)
I’ve tried following tutorials such as this one, but I believe the problem is that it requires a 64-bit environment since I get this as a response:
E: Unable to locate package mongodb-org
So my question is, how can I upgrade my environment to 64-bit? I’ve tried editing the config.txt and now I get this for “uname -a”:
Linux DietPi4 5.10.11-v8+ #1399 SMP PREEMPT Thu Jan 28 12:14:03 GMT 2021 aarch64 GNU/Linux
Yet, it’s still unable to locate the mongodb-org package. Any advice?
changing config.txt will not switch your system from 32bit into 64bit. This is simply not possible. The only thing done, is to enable a 64bit kernel mode. However, userland will stay 32bit. To get a real 64bit system, you would need to perform a re-installation using a 64bit image. Since a while, a 64bit BETA version of Raspberry OS is available and supported by DietPi.
Thanks, Joulinar! Sorry about that. I’m still learning how kernels work. So I’ll have to do a full reinstall using a 64-bit OS if I want to attempt it again. Though, as you mentioned, it might not be supported at all.
I might also try Docker as WarHawk suggested. I’ve already put a lot of work in on setting things up, so I’d rather not wipe if possible.
