Nanopi R5C led lights not staying on
  • DietPi version | 9.7.1
  • Distro version | bookworm
  • Kernel version | 6.6.44-current-rockchip64l
  • Architecture | arm64
  • SBC model | NanoPi R5S/R5C (aarch64) or (EG: RPi3)
  • Power supply used | 5V3A
  • SD card used | emmc
  1. LED lights don’t stay on after reboot.
  2. There is no LAN traffic indicstor option (or netdev doesn’t show)
Added by DietPi:
This is saved in dietpi-led_control.rules, it works after setting, but on reboot, only the red heartbeat is on.
SUBSYSTEM=="leds", KERNEL=="green:lan", ACTION=="add", ATTR{trigger}="r8169-1-100:00:link"
SUBSYSTEM=="leds", KERNEL=="green:wlan", ACTION=="add", ATTR{trigger}="hci0-power"
this is the content of dietpi-eth-leds.rules
SUBSYSTEM=="leds", KERNEL=="wan_led", ACTION=="add", ATTR{trigger}="netdev", ATTR{device_name}="eth0", ATTR{link}="1", ATTR{rx}="1", ATTR{tx}="1", RUN+="/bin/ip l >
SUBSYSTEM=="leds", KERNEL=="lan1_led", ACTION=="add", ATTR{trigger}="netdev", ATTR{device_name}="eth1", ATTR{link}="1", ATTR{rx}="1", ATTR{tx}="1", RUN+="/bin/ip l>
probably something @MichaIng could help with
Oh, LED device names changed from vendor kernel to mainline kernel? Let me check on NanoPi R5S.
root@NanoPiR5S:~# l /sys/class/leds/
total 0
lrwxrwxrwx 1 root root 0 Jan  1  1970 green:lan-1 -> ../../devices/platform/gpio-leds/leds/green:lan-1
lrwxrwxrwx 1 root root 0 Jan  1  1970 green:lan-2 -> ../../devices/platform/gpio-leds/leds/green:lan-2
lrwxrwxrwx 1 root root 0 Jan  1  1970 green:wan -> ../../devices/platform/gpio-leds/leds/green:wan
lrwxrwxrwx 1 root root 0 Jan  1  1970 mmc1:: -> ../../devices/platform/fe310000.mmc/leds/mmc1::
lrwxrwxrwx 1 root root 0 Jan  1  1970 red:power -> ../../devices/platform/gpio-leds/leds/red:power
Okay fixed for next release: v9.8 · MichaIng/DietPi@e7131f8 · GitHub
You can apply this config:
cat << '_EOF_' > /etc/udev/rules.d/dietpi-eth-leds.rules
SUBSYSTEM=="leds", KERNEL=="green:lan", ACTION=="add", ATTR{trigger}="netdev", ATTR{device_name}="eth0", ATTR{link}="1", ATTR{rx}="1", ATTR{tx}="1", RUN+="/bin/ip l s up dev eth0", RUN+="/bin/ip l s down dev eth0"
SUBSYSTEM=="leds", KERNEL=="green:wan", ACTION=="add", ATTR{trigger}="netdev", ATTR{device_name}="eth1", ATTR{link}="1", ATTR{rx}="1", ATTR{tx}="1", RUN+="/bin/ip l s up dev eth1", RUN+="/bin/ip l s down dev eth1"
SUBSYSTEM=="leds", KERNEL=="green:wlan", ACTION=="add", ATTR{trigger}="netdev", ATTR{device_name}="wlan0", ATTR{link}="1", ATTR{rx}="1", ATTR{tx}="1", RUN+="/bin/ip l s up dev wlan0", RUN+="/bin/ip l s down dev wlan0"
_EOF_
It assigns the WiFi LED as well.
