By default on NanoPi Neo, the blue system LED is always off and has no function.
Update:
- Since DietPi v.143 blue LED is heartbeat for H3 now functional and applied during boot.
Hint:
- this will ONLY work with Legacy kernel images (3.4x) at the moment
- NOT with Mainline kernel images (4.9.x) ==>> green Power LED will start blinking, if device is ready for login
root@NanoPi-Neo:~# uname -r
List available options:
root@NanoPi-NEO:~# cat /sys/class/leds/blue_led/trigger
[none] mmc0 timer heartbeat backlight default-on
Example: Turn off
echo 0 >/sys/class/leds/blue_led/brightness
echo none >/sys/class/leds/blue_led/trigger
Example: link to Heartbeat usage
echo 1 >/sys/class/leds/blue_led/brightness
echo heartbeat >/sys/class/leds/blue_led/trigger
Example: link to SD usage (Note: Only after completely booting up device! )
echo mmc0 >/sys/class/leds/blue_led/trigger
To get this blue LED changes persistent on every boot, you have to edit /etc/rc.local
Make a backup:
cp /etc/rc.local /etc/rc.local.bac
Edit:
nano /etc/rc.local
Add following lines before "exit 0 ":
[Example - edit or uncomment line you needed.]
#### switch on blue LED for sd-card activity
#### switch on blue LED for heartbeat
## echo 1 >/sys/class/leds/blue_led/brightness
## echo heartbeat >/sys/class/leds/blue_led/trigger
#### switch off blue LED
## echo 0 >/sys/class/leds/blue_led/brightness
## echo none >/sys/class/leds/blue_led/trigger
exit 0
