NanoPi M6 LCD Panel not displaying
  • DietPi version |
  • G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=10
    G_DIETPI_VERSION_RC=-1
    G_GITBRANCH=‘dev’
  • Distro version |bookworm
  • Kernel version Linux MagicCubeSara 6.1.84-vendor-rk35xx #1 SMP Tue Dec 24 13:36:04 UTC 2024 aarch64 GNU/Linux
  • Architecture | arm64
  • SBC model | NanoPi M6 (aarch64)
  • Power supply used | 5V 4A
  • SD card used | emmc module
I am unable to get the LCD to display anything. Using HDMI I have the full desktop.
In the notes in the image download, you mention:
has an LCD display builtin, which can be enabled via device tree overlay in DietPi. A related dietpi-config toggle is added with next release.
How do I add this? Does this need to be done before first boot or can be added after the device boots and installing some packages? What file does it go into and what is the exact syntax?
Thank you.
Something @MichaIng would need to answer
What display do you use and how did you connect it?
its directly connected to the case :smiley:
https://www.friendlyelec.com/index.php?route=product/product&product_id=301
