DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=9
G_DIETPI_VERSION_RC=0
G_LIVE_PATCH_STATUS[2]=‘not applicable’
G_LIVE_PATCH_STATUS[3]=‘not applicable’ -
Distro version |
bookworm -
Kernel version |
uname --all
Linux t62.FQDN 6.1.84-vendor-rk35xx #1 SMP Tue Dec 24 13:36:04 UTC 2024 aarch64 GNU/Linux -
Architecture |
dpkg --print-architecture
arm64 -
SBC model |
NanoPi 6 series (aarch64) -
Mean Well LRS-50-12 (50W/12V) -
System is running from the eMMC
← If you sent a “dietpi-bugreport”, please paste the ID here → - Bug report ID |
echo $G_HW_UUID
Reboot the SBC, either savagely, with “reboot” or with “shutdown -r now”.
eth0 and eth1 should always use the right socket.
The SBC has 2 RJ-45 sockets : ETH1 & ETH2 (yeah bad names :/)
Most of the time, eth1 (static IP - eth0 is down) is using the “ETH2” socket, which is normal as it is the 2nd I/F, but sometimes after a reboot, it moves to the “ETH1” one, which is a concern, as I can’t be sure if it will be the case after each reboot/power shortage - very bad thing for a machine that is also a server.
I did not have had the choice as dietpi-config only showed me eth1.
I’ve 2 other (same) SBC installed with bullseye Debian (FriendlyElec image) that never have had this problem.
I also created /etc/network/interfaces.d/eth1, just in case, but it does not change this behavior.
What might be confusing DietPi is both I/F have the same MAC address (which can be easily circumvented with the “macchanger” PKG if needed).
May be using invariable Ethernet I/F names would help ? And if so, how to do that in DietPi ?
Also, synaptic is hyper slow, and after check, it only uses one core that is almost 100% of the time @100% - it is in fact unusable as it take ~10s to react to whatever order (even a mouse scroll).
