I am creating a new motioneye installation.
I installed dietpi and then installed motioneye but does not start.
The error is:
motioneye.service - motionEye Server
Loaded: loaded (/etc/systemd/system/motioneye.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2020-05-03 18:45:24 -03; 3s ago
Process: 2355 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioneye/motioneye.conf (code=exited, status=1/FAILURE)
Main PID: 2355 (code=exited, status=1/FAILURE)
May 03 18:45:23 DietPi meyectl[2355]: from tornado.log import app_log
May 03 18:45:23 DietPi meyectl[2355]: File "/usr/local/lib/python2.7/dist-packages/tornado/log.py", line 36, in <module>
May 03 18:45:23 DietPi meyectl[2355]: from tornado.escape import _unicode
May 03 18:45:23 DietPi meyectl[2355]: File "/usr/local/lib/python2.7/dist-packages/tornado/escape.py", line 27, in <module>
May 03 18:45:23 DietPi meyectl[2355]: from tornado.util import PY3, unicode_type, basestring_type
May 03 18:45:23 DietPi meyectl[2355]: File "/usr/local/lib/python2.7/dist-packages/tornado/util.py", line 32, in <module>
May 03 18:45:23 DietPi meyectl[2355]: from inspect import getargspec
May 03 18:45:23 DietPi meyectl[2355]: ValueError: bad marshal data (unknown type code)
May 03 18:45:24 DietPi systemd[1]: motioneye.service: Main process exited, code=exited, status=1/FAILURE
May 03 18:45:24 DietPi systemd[1]: motioneye.service: Failed with result 'exit-code'.
Any help will be appreciated
adrian
