Module error on Home Assistant and other requirement
  • DietPi version | latest
  • Distro version | bulleye
  • Kernel version | 6.1
  • Architecture | arm64
  • SBC model | OdroidHC4
  • Software title | Home Assistant
  • Was the software title installed freshly or updated/migrated? Updated
  • Can this issue be replicated on a fresh installation of DietPi? Don’t know
dietpi-software reinstall 157
The installation finish, but during the install it shows this:
  File "<string>", line 1, in <module>
  File "/home/homeassistant/.pyenv/versions/3.11.4/lib/python3.11/tkinter/__init__.py", line 38, in <module>
    import _tkinter # If this fails your Python may not be configured for Tk
ModuleNotFoundError: No module named '_tkinter'
WARNING: The Python tkinter extension was not compiled and GUI subsystem has been detected. Missing the Tk toolkit?
Home Assistant starts fine, but apart from the error above, one integration fails, Scrape, with this error:
Setup failed for scrape: Requirements for scrape not found: ['lxml==4.9.1'].
Did you tried to install missing module manually?
sudo -u homeassistant bash
. /home/homeassistant/pyenv-activate.sh
pip3 install <module>
Noup, I thought it was Home Assistant who installs the requiered modules… I have that integration before the last 2 updates, and there was no error before.
I will try then.
Thank you.
