I have previously used the same hardware to run mjpeg-streamer for my octoprint. I have recently upgraded to bullseye, and am in the process of migrating my services etc over.
I have been
- DietPi version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=16
G_DIETPI_VERSION_RC=2
G_GITOWNER=‘MichaIng’ - Distro version | bullseye
- Kernel version | Linux DietPi 5.10.0-21-amd64 #1 SMP Debian 5.10.162-1 (2023-01-21) x86_64 GNU/Linux
- SBC model | Native PC (x86_64)
- Power supply used | OEM supply
- SD card used | SATA-SSD
- Software title | mjpeg-streamer
- migrated then untinstalled and reinstalled - both didn’t work
← If you sent a “dietpi-bugreport”, please paste the ID here → - Bug report ID | 0a9822e5-d2ff-4bfa-ae74-552bd1edadf1
- using dell wyse systern (native PC) using USB sony eyetoy camera
- install mjpeg-streamer
service should start
service fails
tain from log
journalctl -u mjpg-streamer.service
Apr 09 11:59:46 DietPi systemd[1]: Started mjpg-streamer (DietPi).
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG-streamer [83307]: starting application
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG Streamer Version.: 2.0
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG-streamer [83307]: MJPG Streamer Version.: 2.0
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: i: Using V4L2 device.: /dev/video0
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG-streamer [83307]: Using V4L2 device.: /dev/video0
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: i: Desired Resolution: 640 x 480
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG-streamer [83307]: Desired Resolution: 640 x 480
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: i: Frames Per Second.: -1
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG-streamer [83307]: Frames Per Second.: -1
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: i: Format............: JPEG
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG-streamer [83307]: Format............: JPEG
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: i: TV-Norm...........: DEFAULT
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG-streamer [83307]: TV-Norm...........: DEFAULT
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: i: Could not obtain the requested pixelformat: MJPG , driver gave us: GRBG
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: ... will try to handle this by checking against supported formats.
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: Init v4L2 failed !! exit fatal
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: i: init_VideoIn failed
Apr 09 11:59:46 DietPi mjpg_streamer[83307]: MJPG-streamer [83307]: init_VideoIn failed
Apr 09 11:59:46 DietPi systemd[1]: mjpg-streamer.service: Main process exited, code=exited, status=1/FAILURE
Apr 09 11:59:46 DietPi systemd[1]: mjpg-streamer.service: Failed with result 'exit-code'.
Apr 09 12:06:54 DietPi systemd[1]: Started mjpg-streamer (DietPi).
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG-streamer [83874]: starting application
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG-streamer [83874]: MJPG Streamer Version.: 2.0
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG Streamer Version.: 2.0
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: i: Using V4L2 device.: /dev/video0
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: i: Desired Resolution: 640 x 480
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: i: Frames Per Second.: -1
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: i: Format............: JPEG
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: i: TV-Norm...........: DEFAULT
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: i: Could not obtain the requested pixelformat: MJPG , driver gave us: GRBG
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: ... will try to handle this by checking against supported formats.
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: Init v4L2 failed !! exit fatal
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: i: init_VideoIn failed
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG-streamer [83874]: Using V4L2 device.: /dev/video0
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG-streamer [83874]: Desired Resolution: 640 x 480
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG-streamer [83874]: Frames Per Second.: -1
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG-streamer [83874]: Format............: JPEG
Apr 09 12:06:54 DietPi systemd[1]: mjpg-streamer.service: Main process exited, code=exited, status=1/FAILURE
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG-streamer [83874]: TV-Norm...........: DEFAULT
Apr 09 12:06:54 DietPi mjpg_streamer[83874]: MJPG-streamer [83874]: init_VideoIn failed
Apr 09 12:06:54 DietPi systemd[1]: mjpg-streamer.service: Failed with result 'exit-code'.
Checking out the v4l info on the camera:
v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'GRBG' (8-bit Bayer GRGR/BGBG)
Interval: Discrete 0.005s (187.000 fps)
Interval: Discrete 0.007s (150.000 fps)
Interval: Discrete 0.007s (137.000 fps)
Interval: Discrete 0.008s (125.000 fps)
Interval: Discrete 0.010s (100.000 fps)
Interval: Discrete 0.013s (75.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.020s (50.000 fps)
Interval: Discrete 0.027s (37.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.025s (40.000 fps)
Interval: Discrete 0.067s (15.000 fps)
[1]: 'YUYV' (YUYV 4:2:2)
I am hoping that it may be a missing package that can be installed or possibly modifying the mjpeg-stramer command, however, I am not sure what I can do.
