Minimal Openbox install problems
X I have searched the existing open and closed issues
    G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=18
    G_DIETPI_VERSION_RC=1
    trixie
    Linux DietPi 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1 (2025-09-16) aarch64 GNU/Linux
    arm64
    RPi Zero 2 W (aarch64)
    5V 3A
    SanDisk
    Yes
    d9cf8aae-ed53-4fe5-934b-7eb2e171def8
  1. apt install xorg openbox
  2. touch .xinitrc
  3. cp /etc/X11/xinit/xinitrc ~/.xinitrc
  4. Edit: ~/.xinitrc
  5. Add: exec openbox-session
  6. sudo usermod -aG video dietpi
  7. Run: startx
  • Monitor display with mouse pointer and right click menu.
  • Momentary blank monitor display with no mouse pointer, then console is displayed with frozen command line cursor.
  • Are packages or configuration files missing to install Openbox?
Maybe you should install a regular desktop first? Like lxde from our software catalog? Just as an idea.
Did you install x11 beforehand with dietpi-software?
And can you check x11 logs for errors, to see why it’s not starting.
Jappe,
Thanks! Openbox works after installing X11 using dietpi-software instead of apt install xorg.
Jim
