. I am currently using a LAN cable to connect to the internet.
i think its because of missing drivers but i have no clue as to where or how i can find or install the drivers.
Here are the specs of my Mini PC
CPU: Intel Atom X5-Z8350 Quad-Core
GPU: Intel Gen 9
Processor Speed: Up to 1.92GHz
Process Technology: 14nm
Power Consumption: 2W
Caching: 2MB
RAM: 2GB (LPDDR3)
Internal Memory: 32GB (eMMC)
External Memory(SD Card): Support up to 128GB (not included)
Bluetooth 4.0
Power adapter: 5V
Wi-Fi: 802.11 a/b/g/n/ac
He is trying to find out if your system even detects the hardware, and what chipset it might be
It might end up needing special drivers or config to get it running
Also…what model specifically is your Wintel Pro Mini PC
I think this machine uses a SDIO wifi/bluetooth combo adapter. You can look in the bios if this is the case. The ethernet is connected via USB internally, I think. So the driver for ethernet and wifi are two different ones.
I couldn’t find drivers from realtek for Linux for SDIO wifi cards, only for windows. so maybe realtek does not provide any drivers for Linux for this card at all, but I didn’t spend much time searching.
I’m an average noob at Linux and thought it would be easy to install the WiFi drivers but it looks like it’s easier for me to use an ethernet cable rather than trying to figure out how to get the WiFi working.
