- DietPi version | 8.6.1
- Device: intel pc
- Samsung Duo Plus USB 128gb
My MariaDB service isnt starting, i mounted an external hdd and checked the “use for user data” and deleted the original user data folder because i didnt understand why the original one didnt get deleted.
(i just read that the user data folder will always be in /mnt/ even though the user data is stored elsewhere, so i guess i just deleted all my userdata… luckely everything works as far as i now except that MariaDB doesnt start, and cant be deleted)
But now my mariaDB service doesnt start
And when i delete MariaDB trough the UI i get a error because before i remove it because it tries to start MariaDB to make a backup… which is stupid because i cant start it, thats the problem…
When i delete it trough the purge command it still shows up on the services screen and it still fails to start
I ran: journalctl -u mariadb
Jul 30 12:32:37 DietPi systemd[1]: Starting MariaDB 10.3.34 database server...
Jul 30 12:32:38 DietPi mysqld[865]: 2022-07-30 12:32:38 0 [Note] /usr/sbin/mysqld (mysqld 10.3.34-MariaDB-0+deb10u1) starting as process 865 ...
Jul 30 12:32:38 DietPi mysqld[865]: 2022-07-30 12:32:38 0 [Warning] Can't create test file /var/lib/mysql/DietPi.lower-test
Jul 30 12:32:38 DietPi mysqld[865]: [90B blob data]
Jul 30 12:32:38 DietPi mysqld[865]: 2022-07-30 12:32:38 0 [ERROR] Aborting
Jul 30 12:32:38 DietPi systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Jul 30 12:32:38 DietPi systemd[1]: mariadb.service: Failed with result 'exit-code'.
Jul 30 12:32:38 DietPi systemd[1]: Failed to start MariaDB 10.3.34 database server.
Jul 30 12:39:50 DietPi systemd[1]: Starting MariaDB 10.3.34 database server...
Jul 30 12:39:51 DietPi mysqld[14465]: 2022-07-30 12:39:51 0 [Note] /usr/sbin/mysqld (mysqld 10.3.34-MariaDB-0+deb10u1) starting as process 14465 ...
Jul 30 12:39:51 DietPi mysqld[14465]: 2022-07-30 12:39:51 0 [Warning] Can't create test file /var/lib/mysql/DietPi.lower-test
Jul 30 12:39:51 DietPi mysqld[14465]: [90B blob data]
Jul 30 12:39:51 DietPi mysqld[14465]: 2022-07-30 12:39:51 0 [ERROR] Aborting
Jul 30 12:39:51 DietPi systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Jul 30 12:39:51 DietPi systemd[1]: mariadb.service: Failed with result 'exit-code'.
Jul 30 12:39:51 DietPi systemd[1]: Failed to start MariaDB 10.3.34 database server.
