DietPi is last (current version) downloaded a few days ago
RPi B+
Im in trouble with MariaDB. Im planning to use dietpi as web server (dotnet 6 / mariadb)
My application run ok but i have an error when try to open database, like this described at stackoverflow. I installed mariadb same version as dietpi in my pc with same error, then tested with version prior to 10.10 and the error gone. I cant get to solve it by adjusting my software, so i need to install an older version of mariadb on my dietpi BUT i dont know where to start. Can someone give some advice?
- DietPi version |
cat /boot/dietpi/.version - Distro version |
echo $G_DISTRO_NAME $G_RASPBIAN - Kernel version |
uname -a - Architecture |
dpkg --print-architecture - SBC model |
echo $G_HW_MODEL_NAMEor (EG: RPi3) - Power supply used | (EG: 5V 1A RAVpower)
- SD card used | (EG: SanDisk ultra)
← If you sent a “dietpi-bugreport”, please paste the ID here → - Bug report ID |
echo $G_HW_UUID
